Washer fluid leaks out only when car is on. Washer pump?
Old Oct 11, 2005 | 11:07 AM
Jon-1.8t's Avatar
Old Oct 11, 2005 | 11:09 AM
andysprague's Avatar
Default Our TT does the same thing. It won't leak when the car is off, but if you drive it, it all vanishes.
I haven't figured it out yet though.
Old Oct 11, 2005 | 11:16 AM
BigEd's Avatar
Member
Default Doesn't use oil... but burns off washer fluid ?
I wonder if there's a crack/gap that leaks fluid only when disturbed by vibration.
Need to get in there and look at the tank, pumps and hoses.
Old Oct 11, 2005 | 11:22 AM
Default I was in there once & everything looked OK...
I filled it & let it sit for 2 days & it didn't leak a drop. Then after it was driven again it rapidly dropped. I guess I will have to check again.
I thought my wife was on crack at first, but she was right it is actually disappearing.
For the time being I am just filling it with water every few days to keep the annoying low fluid indicator off. I will have to figure it out soon though since it is getting colder out.
Old Oct 11, 2005 | 11:25 AM
BigEd's Avatar
Member
Default My suspect would be that O-ring (sleeve?) that holds the pump in the tank
That's what was leaking on mine, but it was bad enough to be obvious.
Old Oct 11, 2005 | 11:29 AM
I will check that out. Thanks.
cdaniels
Apr 5, 2020 11:51 AM
a62.7t4ceo
Oct 24, 2007 04:54 PM
eldoj
Sep 11, 2007 08:35 AM
noeltykay
22
Jun 11, 2002 01:14 PM
