After STFA and found the specs on boost for stock ko3 sport(2001) ...
also ... i used vac lines instead of nylon tubing and i have it running over the manifold, just to see how it would work, drove 30 minutes being cautious and the manifold and everything was fine. But it also was 50 degrees out. Will it be of concern when its 70-100 degrees out or with the manifold not melt that thick of wire?
Thanks guys
i stfa and it said 8-12 psi at wot is about right. But i don't know bsk is tellin me numbers like 15 psi stock ... dun dun dun dun dunnnnnn
