Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Audi Q7 2015 (old model) Steering Column
Old Jan 30, 2022 | 08:28 AM
pdpaxm's Avatar
Default Audi Q7 2015 (old model) Steering Column
Hi,
I have just purchased a 2015 (old shape) Audi Q7 S Line Sport with all the bells and whistles!
I can see I have the electronic steering column adjustment and I can move the steering wheel in and out (reach) but not up and down..
Does this mean that motor is broken?
Cheers
Old Jan 30, 2022 | 11:36 AM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Probably not; had same issue in a different car where it was just the switch contacts themselves...sold it, so not my problem, lol. You should try just going through the motions/range of the switch control slowly to see if you can get it to 'twitch' or move in desired direction at all. IIRC, there's also a small 'lockout' button next to the adjuster switch control, so experiment and be mindful of that too. May be able to simply clean the switch by blowing it out with electronic cleaner (air in a can), or dedicated electronic cleaner spray with long straw to deliver where needed.
You need to get a scantool on the car to see what's what under the skin of car anyway, so that's the first real troubleshoot step to get you on right path. If you plan to DIY your car, get tool that helps you DIY and can actually fix things, like Ross-Tech VCDS. If you aren't going to DIY your own car services or work on it yourself, then a cheap, convenient, VAG-compatible diagnostic scantool will allow you to view trouble codes and clear them; like the OBD-Eleven wireless module that works with smartphone app, etc...about $50-$60 for the basic module (don't buy the upgrades).
Old Jan 30, 2022 | 09:28 PM
flynavy's Avatar
Default OLD? I prefer classic my self
It is so close to the original pikes peak show car that was renamed the q7 that it is pretty amazing. Go to the Audi museum and see it some time, it’s what made me initially want a q7
Old Jan 30, 2022 | 10:38 PM
pdpaxm's Avatar
Many thanks for the replies, I can see that a possible reset might cure this, does anyone know if the ODBeleven PRo edition can do this I have the BASIC but I can upgrade
Cheers
Old Jan 31, 2022 | 12:02 AM
emailpeter's Avatar
Very common for steering up & down to jam. Owing to heavy force withholding it while one exits the car. Not to be used as leverage to exit car.
Yes,
VCDS should be able to do that.
[Select]
[09-Cent. Elect.]
[Basic Settings]
Group 001.
Old Jan 31, 2022 | 12:53 AM
pdpaxm's Avatar
Ajh ok but not ODBeleven PRo?
Old Feb 1, 2022 | 09:47 AM
Default OBD-ELEVEN Coding
The OBD 11 only allows modifications and/or long-coding access if you pay for the PRO or higher level subscription; then you have to figure out how to do it either by reading the dedicated forums for that device, or trying to learn from the Ross-Tech forum and apply that through the OBD 11 interface.
The OBD 11 offers very few 'one-touch' programming options for the Q7. Most changes or mods requires you manually go in and navigate, so you have to know exactly what you are doing to achieve desired results and not screw up something else. You really can't experiment w/o paying for the upgrade to PRO level subscription, which is a bit pricey for the amount of uncertainty involved. I can tell you they oversell the upgrade to the 'PRO' programming access...it really isn't great for the Q7, and not worth the extra $$ to subscribe to the higher level 'coding' access you need to change anything on the car.
Before you pay them anything, go read the forums on the OBD-11. Do remember that it's an annual subscription, whereas the Ross-Tech VCDS setup is buying the cable only; the software required to use it is free, and there's a ton of info on coding/maintaining/fixing issues encountered on the Q7.
Old Feb 2, 2022 | 12:42 AM
pdpaxm's Avatar
Thanks for the update, looks like the VCDS to OBD11 is:
Pretty easy to translate:
1) Open app and connect to car
2) Press the burger icon to get to the control unit list
3) Select control unit 09
4) Select basic settings
5) Open channel/group 001
6) Press green tick to activate the basic settings
7) You should see that it's working (changes states)
8) Once everything is done exit the basic settings
9) Done
but not sure if I dare do it!
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 3, 2022 | 02:00 PM
You won't be able to do/access coding unless you pay for the Pro-level, ANNUAL SUBSCRIPTION, on the OBD-Eleven platform. You will also find out that OBD-Eleven will allow you to go deep into coding attempts before it tells you that the function is not supported...ask me how I know. That's the primary reason I don't recommend it for advanced coding functions...you pay an annual fee for very limited coding access. It's great for the basics though, but they generically oversell what the device can do, as it won't actually do a heck of a lot on the Q7 chassis...they just haven't developed out their coding/access to car like they have on multiple other VW models, then they will tell you you can only do that if you buy the second-tier, NEXT LEVEL subscription, which is much, much more expensive...ask me how I know. I was quite angry about that bit...lots of upselling going on...very little results.
If you are going to spend/invest the money to be able to DIY, buy it once (VCDS), and be able to do everything you need to do on your Q7.
White Shark
Audi Q8
Mar 24, 2021 01:59 PM
Jarryd-Seth Ernstzen
A4 (B8 Platform) Discussion
Oct 19, 2020 07:46 AM
AT90qubed
Aug 18, 2007 09:06 AM
Brdman*
11
Jun 19, 2007 01:50 PM
back2black
Jun 16, 2004 08:43 AM
