Looking at buying an’09
We are going to look at an ‘09 3.6L with 250k kms.
It would be a cash deal, and the price seems about right for the market around here (Eastern Canada). $6000 CAD. We are moving on from our older Ford Expedition that is a little rough around the edges and needs several thousand in repairs in order to pass inspection again.
I don’t drive very much - about 8k kms a year. Mostly little trips around town to grab the kids from school or groceries. We do tow our camper in the summer - which is primarily what this rig would be used for. Short trips around the province on weekends. We are hoping to get 2 decent years out of it before we buy something new.
With all that considered - this rig only has faulty park assist and adaptive headlights (according to owner). What are some things I should be looking closely at? What might be some red flags?
We are not new to the VAG group. We have owned many VW (wife’s current car is a newer Passat TDI). Part of the appeal here is the Audi brand - with some decent luxury features compared to my old Ford, along with the towing capability.
Thoughts and recommendations are greatly appreciated.
Regarding the 3.0 TDI's....
Edzzed suggests you check out a diesel if possible. I test drove one and I really liked it, very smooth and quiet, with a lot of low end torque. If you do consider a TDI, make sure to check and see how much diesel-gate warranty is has left - if any. Plug in the VIN number into the Audi TDI Warranty Emissions Look-Up here....https://audidiesellookup.com/. If a TDI doesn't have any warranty left, then I would not buy it unless it's dirt cheap and I had sufficient funds set aside to fix things. The TDI's are awesome but as Edzzed relates in only 2 years of ownership the engine was dropped to fix oil leaks, new DPF, injectors installed, and finally a whole new fuel system (probably due to HPFP failure). I would guess these repairs would easily add up to more than $20,000. I'm currently looking for a nice TDI but reading about the common issues does scare me a bit..
one other thing…the sunroof frame (plastic) cracked causing the sunroof to get stuck. Dealer wanted $1,500 to replace. I drilled small holes on either side of broken fram, inserted super glue and a short metal rod to connect the two sides. Cost…$10.
1. Driver outside mirror motor failed.
2. ATF leak at the transmission electrical connector. If you don't DIY it will cost at least $1,000 USD, but you get an ATF change which you should probably do anyway.
3. Coolant leak where the "crack pipe" enters the rear of the water pump. Also costs at least $1,000 USD but you get a coolant change which you should probably do anyway.
(both of the above leaks were at o-rings which I assume shrank with age).
4. Lane keep assist module failed. I did DIY replacement with an ebay part.
5. Lane change assist module failed. Don't know if I'll try to fix or not.
6. Sunroof leak into front passenger area. An extremely common Q7 problem.
Not too long before I bought it the first owner has the fuel pump and valve cover gasket replaced.
Replacing the oil filter is so difficult that it's hard to believe without actually having been a victim of doing it.
When it's working well, it's a nice solid and comfortable car.
But just like tigerwillow1 above says....it's a nice vehicle when all is working, and I still loved it. I had the tow package and air suspension which was really nice, never had any issues. We pulled a trailer with about 5,000 pounds from Michigan to Alabama several times with no trouble. We pulled stumps, hedges...hauled masonry....I was really proud of how well the Q7 handled it all.
Do be aware that the next model year (2010) gave the car an exterior facelift, with different headlights, LED turn signals front/rear, and some different engines to choose from
I went and looked at the ‘07 and decided to pass on it. There were a few red flags for me, so best to walk away if my instincts are telling me to.
Now we are considering a ‘13 with 170k kms for 14k CAD. It’s also the v6. It’s a trade in at a dealership and has very good service history. It’s been well taken care of.
Is there anything in particular with these next gen ones that I should be looking at specifically?
Thanks again!
