NZ: Gateway module replacement - is CP removal involved ?
if NO, it's goooooood .... if Y :
-) only gateway module ?
-) gateway and other modules ?
-) other options ?
thank you for response.
at this moment the only way for me is to do it and see what will happen .... disappointed with absents 100% sure info
I had chat with a Auckland dealer, with foreman of diagnostic team ... and guess what he said ... he sad EVERYTHING in MMi system after replacing Gateway module (incl Gateway module itself) needs to be process on CR removal ... I asked again everything? .. including radio unit? - he said YES. .... HOW CAN I TRUST a dealer if Radio unit doesn't have CP ... I do not have a choice ... dealer holds monopoly on Audi plant server information (I cannot pay for monthly subscription) ... they treat us as idiots. I try to be diplomatic when I describe my feeling about dealer service.
Inquiring minds want to know
.Last edited by '10Q7TDI_Prestige'; Feb 8, 2022 at 01:11 PM.
Battery is new (1 year old), internal resistance 3.2, full in charge now and I always use CTEK MX40 when work with the car ... and of course I have legitimate VCDS
After replacing programming 2nd working BM unit I had the same 01299.. Wiring can be a problem but to get to GW module to "ring" all wires I had to remove GW module. to remove GW module it is the whole STORY , because is it buried very deep under the dash. Since I have original GW module on my hand (replacement is coming) I decided to replace it and see how the system responds. If gateway module has it's own CP , I will be get stuck until CP is removed, if NOT, battery management has to respond ( I know the unit I bought is in good working condition ) .
... would be very helpful to have wire diagram to "ring" cable from BM socket to GW module socket while I'm waiting for delivery .... can somebody help me please with wiring diagram if it's possible?
... that is the plan ....
None of that requires much time, effort, or cash, and you don't have to worry about security-coded modules.
ok ... my first scan after purchase showed handles sensors fault (all of them) ... I bought new handles ... they sit on the bench, waiting to be installed ... I have to admit after checking youtube video handles replacement, I am still a bit afraid to do this job ( it looks to me as “guess” job – nothing visible to manipulate with … or Am I overthinking? ) … found two video but they are in russia lang ... they look convincing ... will try to do job on weekend
… relays – Yes, bough 2 weeks ago some, still travelling somewhere – weird service during Covid time.
… thanks for the tip “small monitoring wire” will look into it deeper …
My life is very busy with work … only weekends are for cars … will report of my results after weekend.
You will find out that those constant parasitic drains take a heavy toll on the battery over time, which leads to all sorts of bad behavior in this highly voltage-sensitive car, which is networked from end-to-end. Fix the parasitic drains, clear the errors, get your battery voltage and amp hour capacity/internal resistance #'s back up to where they should be, (replace those old relays) and re-assess.
