q7 4lb 3.0 tdi "Temperature prior - Precatalytic Converter"
As to the 'temp' reading sticking, that's a classic symptom of a bad sensor, or it being in a default loop due to bad sensor. I had that happen when my EGR Cooler went out...temps spiked and cooked the downstream exhaust temp sensor, which threw the system into a default loop, and the car reduced boost, etc., to reduce the temps reported...limp-mode, basically. Be sure to check your coolant reservoir level
Be sure to check your coolant reservoir level to see if it's low or nonexistent...that's a sign of an EGR Cooler leak, which causes downstream sensor failures, feedback loop issues, limp-mode, etc. While that may not be your base issue, it's certainly easy to check for. The TDI models also get very thick carbon/soot deposit build-up in the intake tracts/EGR system, etc., over time related to being a direct-injection engine, which narrows the air passages down to the point where you'll wonder how it still runs at all. Had the EGR Cooler replaced at 108k miles on our 2010 TDI, and it was coked-up so severely inside that Audi actually cleaned it out gratis prior to reassembly; didn't even notify me about it...a very rare thing in the USA where they prefer just to sell you new intakes rather than de-coke the old ones. Liqui Moly has introduced a TDI intake cleaner spray (introduced via vacuum line) to address the soot/carbon build-up issues w/o having to disassemble the car.
I've had two different emissions sensors go out; one threw the adblue monitoring system into panic mode, and threatened to disable the car, although the adblue tanks were full and functional. The other related to the EGR Cooler failure, which allows too much exhaust heat to pass through and damages the downstream sensor bits; it put the car into a protective 'loop' and cut power output...all seemingly unrelated to emissions sensors. Look for what can be creating the data point, not just at the data point itself
.Good luck!
