Custom-fit Wireless Charger for 2015 Q7 Center Console?
P.S. - thanks to this post for helping me to remove the trim on the console: Changing out the center console? - AudiWorld Forums
I've searched around quite a bit, but haven't been able to find a custom fitting solution to installing a wireless charger (Qi) into the bottom of the center arm rest console, in (or replacing) the felt-lined storage area. Any leads or ideas on a clean wireless charger install?
I will recommend you to purchase a Carplay kit from a local vendor, so in case the worst happens and you get one that craps out or doesn't work out-of-the-box, you have an easy recourse and support system in place to take care of the return, etc. Amazon and the 4X4 store/shop are two such vendors in the USA. If you live in another country, use the internet to search and locate a vendor in your region that has an excellent service/return policy. I do believe Amazon also offers an extended warranty add-on, which is likely worth it, IMHO. Most of the vendors you will find are in China, which is only a bad thing when you need service/support on the product. Even the ones you buy on Amazon are made in China, but you are dealing with Amazon's return policy, and speed of processing, which makes all the difference.
