Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Audi Q7
Old Feb 17, 2022 | 11:08 PM
bboa's Avatar
Default Audi Q7
Hi, I have a 2016 audi Q7 S Line. It has stared to a humming noise seemingly coming from the engine when turned on. This noise doesn't seem to increase or decrease with speed or acceleration and in fact stays on briefly after the car is turned off. I have now warning lights or performance related issues. At a loss as to what's causing it. Any help would be appreciated
Thanks in advance.
Old Feb 18, 2022 | 05:44 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Default Wrong Forum; Go Directly to Q7 Mark 2 (2016 - ?)
Thanks in advance.
Those newer, 4M chassis, Q7 MARK II cars all have the stop/start, mild hybrid system incorporated, and that's likely what you are noticing, if I had to venture a guess. Audi also has multiple coolant pumps, fuel pumps and other electrical gizmos you could be hearing, some of which remain active and running post-shutdown. Radiator fans are also fairly quiet and can remain on past engine shut-down. I recall getting a bit worried once when I heard a humming ...in my case, it was my aftermarket, LED, fan-cooled foglight bulbs, which the car lights up for a set time as parking lamps when I turn off the car. As your newer model was a clean-sheet redesign, go check in with the dedicated forum for your year model Q7, if the noise still seems abnormal to you.
Good luck!
Old Feb 19, 2022 | 01:38 PM
bboa's Avatar
Good luck!
apologies, didn’t realise I posted in the wrong place. Can you advise where to post.
thanks
Old Feb 19, 2022 | 02:24 PM
Edzzed's Avatar
thanks
Here is 2016 and newer. https://www.audiworld.com/forums/q7-...iscussion-211/
dreni998
Q3 Discussion
Jun 29, 2021 05:16 AM
l l
Aug 24, 2019 06:15 AM
Husk
A4 (B8 Platform) Discussion
Aug 5, 2019 02:56 PM
whyman
Q5/SQ5 MKI (8R) Discussion
Aug 1, 2018 07:06 PM
bos_man
Q7 MK 1 Discussion
Mar 29, 2010 01:15 PM
