Audi Service: The Audi 'Eye-Tick' Scenarios
), or their best attempt to separate you from the contents of your wallet.Car's in shop; persistent tiny coolant leak is not hitting ground...can smell the coolant cooking off engine cases; EGR related, surely. I mention an annoying engine whine noise that varies with speed of engine. I suspect it relates to the idler pulleys or alternator pulley not getting replaced when alternator was swapped out by selling dealer...possibly the PCV diaphragm is busted (a TSB item related to engine noise) I didn't tell them it's been making the noise since I picked up the car from dealer a year ago, just to see what they would come up with on their own.
Dealer tells me noise is the A/C compressor, they've got one in-stock, and for the low buy-in of only $3500 they'll swap it out and recharge the system. I'm not now, nor have I ever had any A/C problems with the car...red flags started popping up all over. The small leak, they say, is at the EGR coolant bypass valve, and not covered via warranty; that'll be $2300 and we'll get right on it for you. I say, "send me the validation pics of leak and walk-around video of the car with A/C running and then with A/C off. They seemed a bit shocked I would question or ask for proof of the validity of their diagnostics. A prior Audi shop never did find the leak, even when i told them where to look and what tool to use, but they were awfully quick to suggest I pay them $2200 to "go through the 'system' all the way down to the cases to figure it out."I could feel my anger rising and the "Audi Eye Twitch" manifesting; Nope, so not worth it...I picked my car up. Runs great, everything works fine, I carry a bottle of coolant premix to top off reservoir if needed, and check levels weekly. Cost: $26 for a gallon of concentrated, special-good, violet colored, Euro-style coolant, diluted down w/distilled water in a gallon-sized water jug. A single, full strength gallon of coolant dilutes down to make several gallons, and is a much better value than buying a gallon jug of the 50/50 premix for nearly the same cost. You always pay dearly for convenience.
I wasn't born yesterday, folks. I DIY my own cars, and I know when something is broken or not, and what is a minor concern vs a major concern that requires immediate preventative action or repair. Be careful out there in Audi-dealer land, as they can talk a good game. Go and support your local indie German car repair shop if you need help, or just to get a second opinion, if you don't know much about cars.
