Low coolant level (2009 Q7 3.6L)
Should I have Audi service check it out or add enough coolant so it covers the MIN sign (second screenshot)?
Coolant level in my 2009 Audi Q7
https://www.autozone.com/antifreeze-...on/1050534_0_0
Your car is old enough there could be a number of possibilities as to the leak source, whether it be a cracked fitting, hose, connect pipe,coupler, etc. If it's under the hood, you should be able to smell coolant, especially if it's dripping down onto the engine cases and then evaporating off the hot cases. I'd start by topping it off so the max is just covered over by coolant, giving you an easy reference point. Check it regularly cold for a few days after filling to be sure no air was trapped/released and top it off to same level point as needed, then monitor less frequently, etc., and see what happens with the reservoir level. On mine, i can roll the window down and catch the scent of coolant, but inside the car you get absolutely nothing with the windows closed up tight, not a whiff. Sniff at the hood seams while it's running, or turn off and lift hood and breathe in...is that the sweet, sickly smell of coolant methinks?
Good luck.
