Q7 4-pin towing adapter
This looks like it would do the trick:
And amazon claims it will fit the Q5, but.... will it? Does anyone have any advice? I'm not sure it will fit.
Pics of the existing wiring on my Q7:
Side view
(I can't find a way to edit my original post, is that something only paid members get to do?)
If you tow a trailer with LED brake lights (most any new trailer, RV, or U-haul rental trailer these days), then you will require the Curt LED adapter (under $20) for the Q7s 7-pin output. The Curt adapter plugs into Q7s 7-pin, and then outputs to a 4/5pin connector to match-up to a standard trailer wiring configuration...this adapter is what makes the trailers LED brake lights function correctly and not throw codes in the car that the lights are out on the trailer...also converting from 7pin to the 4/5pin output.
Curt and Pollak also make the 7 way socket you need, I got my Pollak on Amazon.
that socket you found looks like it will work.
You’d think by 2017, the Q7 would be able to handle LED trailer lights without a special adapter.
I can’t find what I need.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Thanks guys
