Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Audi q7 4.2 fsi engine replacement.
Old Mar 2, 2022 | 12:37 AM
binso's Avatar
Default Audi q7 4.2 fsi engine replacement.
Hi everyone.
I have a 2007 Q7 4.2 fsi. The timing chain broke on it. Instead of rebuilding that engine I found one that has 146k km on it and bought that.
I will have it on my garage floor. I am going to go over it and fix all oil leaks before swapping.
Anyone have any tips on what maintenance I should do since the engine will be on my floor?
Old Mar 2, 2022 | 07:14 PM
testarossaguy's Avatar
That would be a great time to install new a timing chain & guides. Also replace the O-Rings on the ends of the water pipes that run through the upper left & right cam chain covers.
Old Mar 3, 2022 | 02:12 AM
binso's Avatar
Yeah I was going to do that. Would there be anyhing else I would regret not changing prior to the engine going into the car?
Maintenance i was looking at doing while it´s out of the car is;
clean the intake manifold
Valve cover gaskets
valley pan gasket
Also heard that the upper engine oil pan can start leaking, going to check that out aswell.
Old Mar 3, 2022 | 12:06 PM
Yes upper & lower oil pan surfaces are known to leak. I'd replace the thermostat too. As for sealing surfaces up that don't have a gasket, I've used Hondabond and it is fantastic stuff - though a bit pricey.
Old Mar 3, 2022 | 11:57 PM
Mxeryus's Avatar
Check all the tubes. Clean the engine - makes it easier to spot any leakages. Looks better too when opening the hood....
Sue Keppler
2.0T FSI Discussion
Jun 19, 2021 08:17 PM
angrypengu
A8 / S8 (D5 Platform) Discussion
Dec 23, 2020 07:52 PM
Per-Tore Pettersen
Aug 20, 2020 06:00 AM
Rusty Spokes
12v V6 Discussion
May 29, 2015 09:06 AM
cj750rock
Aug 30, 2004 06:47 PM
