2104 Shocks Q7 TDI
No reviews on the off name brand kits so I dont want to try them. Only other option is to replace the back ones with these kits ones and see how they ride before changing out the fronts. I am also changing out the upper arms since i have to remove them to do the fronts anyhow.
Thanks,
Don't forget the new strut mount bearings, new urethane bump stops, dust boots, and the possibility of adding on some small booster springs in the rear if you tow with yours.
If you already got the B4's then just take the assemblies to a local shop, see if they give you a better deal than $40 an assembly. Make sure the mount orientation is exactly as the old assemblies. I have not tried turning the mounts afterwards, therefore I am not sure if that would be possible. My rear control arm bushings were so hardened, that trying to press them down as in FSM was real hard. I had to loosen the inner upper arm mounting bolts. Keep new hardware on hand, as these are torqued to yield.
I used TRW front UCAs. These came with a new ball joint nut, but not the mounting bolts and nuts. I picked up new ones from the local dealer. Torqued to yield. I remove the UCAs after pulling out the front struts. The two rubber bushings were shot. I guess I could have just replace the bushings. They pushed out easily when I practiced on the old UCAs. The ball joint and boot were still fine, could have just replaced the bushings. But you won't know until you checked them.
The front lower control arm hydro bushing may have failed by now. If you can press in a new bushing that would be about $30. A new Lemforder LCA would be about $350. I would not use cheap control arms on this heavy beast. I have not done anything regarding LCAs yet.
https://www.rockauto.com/en/catalog/...assembly,15174
Thanks,
If you do swap the upper/lower arms, realize those are made of aluminum and worth some significant bucks at the recycler...don't just toss them out w/the garbage.
FCP Euro sells those also in the Lemforder/TRW versions, IIRC in both a partial and full kit.
Thanks for all the info!
My shock (strut) bumpers were all still good, but the dust boots fell apart. FCP only included two front shock bumpers and NO dust boots. Very weird. I used aftermarket dust boots, they will not clip into the mounts like the factory ones, but worked fine placed over the shock bumpers. The bumpers will stay at the top near the mounts, and that holds the dust boots up.
https://www.fcpeuro.com/products/aud...-7l8413032ekt2
