Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Battery controller module problem
Old Mar 8, 2022 | 04:46 PM
Raj800's Avatar
Default Battery controller module problem
Hey folks
now since I had that slow crank and not starting issue I found it’s most likely starter and the battery is not in a good health
now if I try to connect VCDS it doesn’t get response from the battery controller module gateway 61
anyone had this problem and fixed
do I have to replace the Bcm and code it or just replace the new battery and it will start communicating?
year 2013
battery not enough cca
alternator is working good tested
Old Mar 9, 2022 | 05:18 AM
testarossaguy's Avatar
Don't know if this will help, but I recently read through a thread on a similar issue for Audi A5.....link below....hopefully same issue....
https://www.a5oc.com/threads/vcds-61...troller.69537/
Old Mar 9, 2022 | 08:40 AM
Pothole5000's Avatar
Originally Posted by Raj800
Hey folks
What year Q?
The Ross-Tech Wiki is a great resource, tells you that new Q7's do not have module 61, the battery stuff is moved to module 19-CAN Gateway.
Audi Q7 (4L) - Ross-Tech Wiki
Old Mar 9, 2022 | 09:18 AM
Raj800's Avatar
Originally Posted by Pothole5000
What year Q?
hey mate it’s 2013
Old Mar 9, 2022 | 09:19 AM
Raj800's Avatar
thanks mate I will
have a look
Old Mar 9, 2022 | 09:20 AM
Raj800's Avatar
Let me find out where is that Bcm located in 2013 though
Old Mar 9, 2022 | 11:24 AM
My 2014 is under 19-CAN Gateway, I would be all the 2011+ facelift Q7's are that way.
Halfway down this page is how to do it in the 19 module.
Battery Replacement - Ross-Tech Wiki
Old Mar 14, 2022 | 08:19 PM
Raj800's Avatar
perfect mate fixed battery coding enter I didn’t have the the serial no of the battery but change the old one with a digit and saved
 Pouria Savadkouei
 Michael S. Palmer
RACCAR
A4 (B9 Platform) Discussion
Jan 31, 2022 07:20 AM
Jacek Nowak
Aug 9, 2020 01:20 PM
A8Pete
Jul 28, 2016 03:58 PM
A4QuattroV6
Dec 17, 2015 05:32 AM
odoboyusa
Jun 23, 2015 09:29 AM
