Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Vaccum pump and misfires
Old Mar 9, 2022 | 12:20 AM
zied012's Avatar
Default Vaccum pump and misfires
Hello, I just purchased the Ross-Tech to diagnose my 2007 Q7 4.2 FSI.
There are some weird issues, it seems the vacuum pump doesn't work that well after the vehicle is stopped.
Because of this, and with the battery still flat, I can charge the battery and leave it disconnected and all is well, I did a load test on the battery and it's still good. The alternator also seems to be working fine, so what causes the power consumption and the battery to die when driven normally.
what did you think about these faults and what components were damaged?
I will post the scan of my first diagnosis. Any advice would be good.
Code:
 Chassis Type: 4L (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 14 15 16 17 18 19 1D 1E 20 27
          28 2E 34 36 37 3D 3E 42 46 47 4C 4E 4F 52 53 55 56 57 5E 5F
          61 62 65 66 67 6C 6D 6F 72 75 76 77 7F
VIN: WAUAV54LX8D004288   Mileage: 199300km-123839miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Cannot be reached 1100
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
14-Susp. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Cannot be reached 1100
1E-Media Player 2 -- Status: Cannot be reached 1100
20-High Beam Assist. -- Status: Cannot be reached 1100
27-Ctrl Head, Rear -- Status: Cannot be reached 1100
28-HVAC, Rear -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Cannot be reached 1100
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
37-Navigation -- Status: Malfunction 0010
3D-Special Function -- Status: Cannot be reached 1100
3E-Media Player 4 -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: Cannot be reached 1100
4E-Ctrl Head RR -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Cannot be reached 1100
5E-Ctrl Head LR -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
66-Seat, Rear -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Cannot be reached 1100
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
7F-Inform. Electr. II -- Status: Cannot be reached 1100
Address 01: Engine        Labels:. 079-907-560-BAR.clb
   Part No SW: 4L0 910 560 H    HW: 4L0 907 560 A
   Component: 4.2l V8/4V          0020
   Revision: 71H21---    Serial number:
   Coding: 01210010190F0560
   Shop #: WSC 31414 790 00001
   VCID: 2D51BCB3B41137EE88-8078
7 Faults Found:
000017 - Bank 1: Camshaft A (Intake)
               P0011 - 004 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:39:50
             Freeze Frame:
                    RPM: 1104 /min
                    Load: 51.0 %
                    Speed: 4.0 km/h
                    Temperature: 64.0�C
                    Temperature: 43.0�C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.462 V
005241 - Brake Boost Vacuum System
               P1479 - 008 - Mechanical Failure
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:40:22
             Freeze Frame:
                    RPM: 1759 /min
                    Load: 57.6 %
                    Speed: 17.0 km/h
                    Temperature: 63.0�C
                    Temperature: 41.0�C
                    Voltage: 13.335 V
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:41:30
             Freeze Frame:
                    RPM: 661 /min
                    Load: 30.2 %
                    Speed: 0.0 km/h
                    Temperature: 54.0�C
                    Temperature: 20.0�C
                    Voltage: 13.335 V
000769 - Cylinder 1
               P0301 - 001 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:41:30
             Freeze Frame:
                    RPM: 661 /min
                    Load: 30.2 %
                    Speed: 0.0 km/h
                    Temperature: 54.0�C
                    Temperature: 20.0�C
                    Voltage: 13.335 V
000770 - Cylinder 2
               P0302 - 001 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:41:30
             Freeze Frame:
                    RPM: 661 /min
                    Load: 30.2 %
                    Speed: 0.0 km/h
                    Temperature: 54.0�C
                    Temperature: 20.0�C
                    Voltage: 13.335 V
000771 - Cylinder 3
               P0303 - 001 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 199279 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 18:01:55
             Freeze Frame:
                    RPM: 1107 /min
                    Load: 30.6 %
                    Speed: 20.0 km/h
                    Temperature: 96.0�C
                    Temperature: 28.0�C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
004952 - Cylinder 2 Ignition Circuit
               P1358 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 199282 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 18:10:42
             Freeze Frame:
                    RPM: 2828 /min
                    Load: 89.8 %
                    Speed: 77.0 km/h
                    Temperature: 102.0�C
                    Temperature: 32.0�C
                    Voltage: 12.954 V
Readiness: 0000 1100
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 FR    HW: 09D 927 750 FR
   Component: AL 750 6A           0998
   Revision: 00H64000    Serial number:
   Coding: 0000504
   VCID: 03053A0B4215119E0E-8056
No fault code found.
Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0087089
   Shop #: WSC 27066 002 104857
   VCID: 295948A380F92BCE64-807C
6 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 199292 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 19:06:16
             Freeze Frame:
                    Count: 196
                    Count: 8515
                    Count: 325
                    Count: 49408
01542 - Yaw Rate Sensor (G202)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 199292 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 19:06:16
             Freeze Frame:
                    Count: 196
                    Count: 8515
                    Count: 324
                    Count: 49408
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 199305 km
                    Time Indication: 0
                    Date: 2022.03.01
                    Time: 07:35:41
             Freeze Frame:
                    Count: 192
                    Count: 8513
                    Count: 128
                    Count: 37632
01486 - System Function Test Activated
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:22
             Freeze Frame:
                    Count: 128
                    Count: 8513
                    Count: 320
                    Count: 47872
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:22
             Freeze Frame:
                    Count: 128
                    Count: 8513
                    Count: 8215
                    Count: 47872
01487 - System Function Test
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 183
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:41:02
             Freeze Frame:
                    Count: 2368
                    Count: 8513
                    Count: 321
                    Count: 46848
Address 05: Acc/Start Auth.        Labels:. 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100783298
   Coding: 0000007
   VCID: 63C51A8BA255B19E6E-8036
   Subsystem 1 - Part No: 4F0 910 131 C
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 335
   Component: FBSAUDIC6 KSG   H27 0080
   Subsystem 3 - Part No: 4F0 910 220 F
   Component: FBSAUDIC6 IDG   H01 0060
Address 06: Seat Mem. Pass
Cannot be reached
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L1 910 732 H    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 387E 077552188
   Coding: 0002003
   Shop #: WSC 00000 000 08192
   VCID: 2F6DA6BBBE1D45FEBA-807A
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000000765044
   Subsystem 3 - Serial number: 0121.05.070000000100011565�
   Subsystem 4 - Serial number: 011565�
2 Faults Found:
00003 - Control Module
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:21
01964 - Control Module for Seat & Steering Column Memory (J136)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:40:02
Address 08: Auto HVAC        Labels: None
   Part No SW: 4L0 910 043     HW: 4L0 820 043 E
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---012    Serial number: 00000030046534
   Coding: 0655400
   VCID: 61C91083B849A38E7C-8034
4 Faults Found:
02874 - Control Module 2 for Central Convenience (J773)
            008 - Implausible Signal
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
             Freeze Frame:
                        ON
02508 - Temperature Sensor for Refrigerant (G454)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
01087 - Basic Setting Not Performed
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 177
                    Mileage: 198975 km
                    Time Indication: 0
                    Date: 2022.02.20
                    Time: 16:13:14
02379 - Positioning Motor for Left Side Vent (V299)
            003 - Mechanical Failure
             Freeze Frame:
                    Fault Status: 01100011
                    Fault Priority: 3
                    Fault Frequency: 6
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:28
             Freeze Frame:
                    Voltage: 13.30 V
                    Temperature: 30.0�C
                    (no units): 195.0
                    (no units): 81.0
                    Temperature: 24.0�C
Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H17 0240
   Revision: 00000000    Serial number: 4F0907279
   Coding: 0013122
   VCID: 3169A0C3A829530EAC-8064
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H13 0080
   Coding: 00008178
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 01788459
   Shop #: WSC 31414
Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
   Part No SW: 4L0 910 110 B    HW: 4L0 035 110
   Component: MP3-Changer     H43 0390
   Revision: 00043000    Serial number: AUZ5ZBG1066066
   Shop #: WSC 00000 000 00000
   VCID: 1E336B7FC9B7DC7601-804A
Address 0F: Digital Radio
Cannot be reached
Address 14: Susp. Elect.
Cannot be reached
Address 15: Airbags        Labels: 4L0-910-655.lbl
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH42 0230
   Revision: 03H42000    Serial number: 00399D0334KL
   Coding: 0014128
   VCID: 2E53BBBFB9174CF6B1-807A
   Subsystem 1 - Serial number: 6332QSME2F5B325FX
   Subsystem 2 - Serial number: 6342QSME2F5B3D31T
   Subsystem 3 - Serial number: 6352QSME2F184F0BX
   Subsystem 4 - Serial number: 6362QSME2B19454BP
   Subsystem 5 - Serial number: 63734SME29331A4B1
   Subsystem 6 - Serial number: 63834SME29331F451
Address 16: Steering wheel        Labels: 4F0-910-549.lbl
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenks�ulenmodul H08 0230
   Revision: 00H08000    Serial number: 90054071230229
   Coding: 0012142
   VCID: 66C3039F5167C4B689-8032
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: Lenkradmodul    H02 0030
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 930 S
   Component: KOMBIINSTR. M73 H21 0220
   Revision: 00600000    Serial number: 6EH31GZ57
   Coding: 2657643
   VCID: 23455A8BE2D5F19E2E-8076
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B0751981FD
   Coding: FDFFFF7FF8FFF70F
   Shop #: WSC 00003 329 88140
20 Faults Found:
03158 - Control Module for Information Electronics 1 (J794)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
03163 - Control Module for Information Electronics 2
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
00380 - Special Vehicle Control Module (J608)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:23
00471 - Control Module for Elect. Regulated Dampers (J250)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:23
01207 - Control Module for Auxiliary Heater (J364)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:24
00461 - Control Module for Seat Memory; Passenger (J521)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
01325 - Control Module for Tire Pressure Monitoring (J502)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
02003 - Driver Identification Control Module (J589)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
00462 - Control Module for Seat Memory; Rear (J522)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
03109 - Tire Pressure Monitoring Control Module 2 (J793)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
00465 - Control Module for Telephone/Telematic (J526)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
00460 - Control Module for Display and Input; Rear (J524)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
02077 - Media Player Position 2 (R119)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
02078 - Media Player Position 3 (R120)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
02079 - Media Player Position 4 (R121)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
00467 - TV Tuner (R78)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
02230 - Digital Radio (DAB) (R147)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
01303 - Telephone Transceiver (R36)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
01301 - Control Module for Voice Recognition (J507)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
02075 - Rear Right Information Display Control Head Control Module (J649)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:58:22
Address 1D: Driver Ident.
Cannot be reached
Address 1E: Media Player 2
Cannot be reached
Address 20: High Beam Assist.
Cannot be reached
Address 27: Ctrl Head, Rear
Cannot be reached
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4L0 910 158     HW: 4L0 919 158 C
   Revision: 00---009    Serial number: 00000030046737
   Coding: 0000006
   VCID: 68DF0DA75B73D2C6BB-803C
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
01320 - Control Module for Climatronic (J255)
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
             Freeze Frame:
                        ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:27
             Freeze Frame:
                        ON
Address 2E: Media Player 3
Cannot be reached
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 C    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7660
   Revision: --H03001    Serial number: 15.1528-0096.2
   Coding: 0015510
   Shop #: WSC 51366 000 1048576
   VCID: 2A5BB7AF85FF20D66D-807E
8 Faults Found:
01316 - ABS Control Module
             Freeze Frame:
                    Fault Status: 11101101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 199305 km
                    Time Indication: 0
                    Date: 2022.03.03
                    Time: 15:59:40
             Freeze Frame:
                    Error Code: 98
00142 - Left Front Dampening Adjustment Valve (N336)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 11101100
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:25
             Freeze Frame:
                    Error Code: 210
00143 - Front Right Dampening Adjustment Valve (N337)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:25
             Freeze Frame:
                    Error Code: 213
00144 - Rear Left Dampening Adjustment Valve (N338)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:26
             Freeze Frame:
                    Error Code: 216
00145 - Rear Right Dampening Adjustment Valve (N339)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 8
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:26
             Freeze Frame:
                    Error Code: 219
01583 - Leak in System Detected
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 224
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:39:33
             Freeze Frame:
                    Error Code: 70
01400 - Suspension Level Control
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 223
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:41:16
             Freeze Frame:
                    Error Code: 66
01769 - Sensor for Vehicle Leveling; Front Right (G289)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 225
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Error Code: 27
Address 36: Seat Mem. Drvr
Cannot be reached
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
   Component: MNS ECE         H49 1030
   Revision: 00000000    Serial number: 399E1077576464
   Shop #: WSC 27066 002 1048576
   VCID: 3E738BFF6977BC7621-806A
1 Fault Found:
02444 - Disk Drive Load / Eject Malfunction
            000 - -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 38
                    Reset counter: 185
                    Mileage: 199202 km
                    Time Indication: 0
                    Date: 2022.02.26
                    Time: 22:45:29
Address 3D: Special Function
Cannot be reached
Address 3E: Media Player 4
Cannot be reached
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00-00000
   Coding: 0064207
2 Faults Found:
02115 - Locking Unit for Central Locking
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:22
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 11
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:22
Address 46: Central Conv.        Labels:. 4L0-910-289.lbl
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H07 0040
   Revision: 0040 ---    Serial number: 01045048110000
   Coding: 7616767
   VCID: 3365AACB5235611EDE-8066
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:      IRUE No Answer
5 Faults Found:
01403 - Glass-Break Sensors; Rear
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 185
                    Mileage: 198241 km
                    Time Indication: 0
                    Date: 2022.01.11
                    Time: 20:40:47
01134 - Alarm Horn (H12)
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 185
                    Mileage: 198241 km
                    Time Indication: 0
                    Date: 2022.01.11
                    Time: 20:40:49
03073 - Rear Lid Closed Sensor 1
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 225
                    Mileage: 199305 km
                    Time Indication: 0
                    Date: 2022.03.01
                    Time: 15:45:06
01135 - Interior Monitoring Sensors
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 185
                    Mileage: 198340 km
                    Time Indication: 0
                    Date: 2022.01.14
                    Time: 17:49:39
02103 - Control Module 2 for Vehicle Electrical System (J520)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 112
                    Reset counter: 162
                    Mileage: 198340 km
                    Time Indication: 0
                    Date: 2022.01.14
                    Time: 18:56:47
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4L0 910 223 K    HW: 4L0 035 223 C
   Component: DSP-AU716-RD  H07 0270
   Revision: 06S00000
   Coding: 060000
   VCID: 2C57B1B74F0B3EE69F-8078
Address 4C: Tire Pressure II
Cannot be reached
Address 4E: Ctrl Head RR
Cannot be reached
Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000226676
   Coding: 0001001
   VCID: 5EB32B7F89379C7641-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00-00000
   Coding: 0064206
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 11
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:22
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 11
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:22
Address 53: Parking Brake
Cannot be reached
Address 55: Headlight Range        Labels: 8P0-907-357.lbl
   Part No: 8P0 907 357 F
   Component: Dynamische LWR  H02 0010
   Revision: 00000001    Serial number:
   Coding: 0000008
   VCID: 3D718CF36471A76E38-8068
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 388E$077627176
   Coding: 0000001
2 Faults Found:
00856 - Radio Antenna
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 225
                    Mileage: 199305 km
                    Time Indication: 0
                    Date: 2022.03.01
                    Time: 16:13:04
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 11
                    Reset counter: 185
                    Mileage: 198831 km
                    Time Indication: 0
                    Date: 2022.02.17
                    Time: 19:14:58
Address 57: TV Tuner
Cannot be reached
Address 5E: Ctrl Head LR
Cannot be reached
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000003689
   Shop #: WSC 74500 745 89398
   VCID: 25414493ECE10FAE40-8070
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2706012203
   Coding: 344630393135313035442056413032373036303132323033
1 Fault Found:
02256 - Quiescent Current
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 3
                    Reset counter: 225
                    Mileage: 199305 km
                    Time Indication: 0
                    Date: 2022.03.01
                    Time: 01:54:45
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0050
   Coding: 0016394
Address 65: Tire Pressure
Cannot be reached
Address 66: Seat, Rear
Cannot be reached
Address 67: Voice Control
Cannot be reached
Address 6C: Back-up Cam.        Labels: 4L0-910-441.clb
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J7442VD
   Coding: 1021001
   VCID: 24475997E7DBF6A657-8070
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 182
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
Address 6D: Trunk Elect.        Labels: 4L0-910-945.clb
   Part No SW: 4L0 910 945     HW: 4L0 827 851 B
   Component: ValeoHeckdeckel H21 0280
   Revision: --H21001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD771B74F8BFEE6DF-8038
   Subsystem 1 - Part No: 4L0 910 946
   Subsystem 2 - Serial number: E5030100B
   Subsystem 3 - Serial number: RD01.06.07--H21001001A0021�
   Subsystem 4 - Serial number: 1A0021�
Address 6F: Centr. Conv. II        Labels:. 4L0-910-290.lbl
   Part No SW: 4L0 910 290 A    HW: 4L0 907 290 A
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 002808336-----
   Coding: 0003843
   VCID: 2643439F91E704B649-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE15_SKB09H10 0180
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE15_SKB09H10 0180
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE15_SKB09H10 0180
2 Faults Found:
01512 - Control Module for Sliding Roof
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 12
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:22
02907 - Control Module for Roof Shade (J394)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 12
                    Reset counter: 185
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 15:57:22
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0016394
Address 75: Telematics
Cannot be reached
Address 76: Park Assist        Labels: 4Fx-910-283.lbl
   Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
   Component: Parkhilfe 8-Kan H12 0080
   Revision: 00H12000    Serial number: 06320713500075
   Coding: 0221146
1 Fault Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 182
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:39:56
Address 77: Telephone
Cannot be reached
Address 7F: Inform. Electr. II
Cannot be reached
End-------------------------(Elapsed Time: 05:24)--------------------------
Old Mar 9, 2022 | 08:37 AM
Pothole5000's Avatar
Lots of faults that all seem voltage related, these cars are very sensitive to battery voltage.
Is your battery new, and if so was it coded to the car correctly with VCDS or a dealer?
Start with clearing all the codes, it is best to click into each module and clear them there rather than doing a mass clear.
The ones that immediately come back are the prime suspects. Start with any that say open short or open circuit, those are the ones drawing power.
Old Mar 16, 2022 | 11:28 PM
zied012's Avatar
AFTER I CHANGED VARIABLE SOLENOID VALVE FOR BANK 1 I RE-SCAN MY ENGINE AND I FOUND:
Code:
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:40:22
             Freeze Frame:
                    RPM: 1759 /min
                    Load: 57.6 %
                    Speed: 17.0 km/h
                    Temperature: 63.0�C
                    Temperature: 41.0�C
                    Voltage: 13.335 V
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:41:30
             Freeze Frame:
                    RPM: 661 /min
                    Load: 30.2 %
                    Speed: 0.0 km/h
                    Temperature: 54.0�C
                    Temperature: 20.0�C
                    Voltage: 13.335 V
000769 - Cylinder 3
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 199260 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 17:41:30
             Freeze Frame:
                    RPM: 661 /min
                    Load: 30.2 %
                    Speed: 0.0 km/h
                    Temperature: 54.0�C
                    Temperature: 20.0�C
                    Voltage: 13.335 V
004952 - Cylinder 3 Ignition Circuit
               P1361 - 004 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 199282 km
                    Time Indication: 0
                    Date: 2022.02.28
                    Time: 18:10:42
             Freeze Frame:
                    RPM: 2828 /min
                    Load: 89.8 %
                    Speed: 77.0 km/h
                    Temperature: 32.0�C
                    Voltage: 12.954 V
Old Mar 17, 2022 | 07:38 AM
testarossaguy's Avatar
005241 - Brake Boost Vacuum System: First check to see if the vacuum pump has power, and determine that it operates and generates vacuum. If it does, then start looking for a vacuum leak somewhere. If there is a vacuum leak it could result in the random / intermittent misfires you are experiencing.
004952 - Cylinder 3 Ignition Circuit / P1361 - 004 - Open Circuit - Intermittent: Possibly a bad ignition coil. You could swap the coil with another cylinder and see if the problem follows, if it does....replace the ignition coil.
Old Mar 20, 2022 | 03:42 AM
zied012's Avatar
I checked the vacuum pump and it works fine, and I need to check where the vacuum leaks are in the circuit.
for cylinder 3, I swapped the ignition coil to cylinder 6 and the fault does not follow, so I swapped the spark plug and the fault does not follow. the fault occurred after starting and above 3000 rpm and sometimes from idle, and when I erased it, it came back instantly.
Old Mar 20, 2022 | 06:15 AM
P1361 Cylinder #3 ignition "open circuit - intermittent" - make sure there are no wire harness / electrical connector issues. If you find a vacuum leak somewhere, fixing that may also fix the "random multiple mis-fires".
Old Mar 22, 2022 | 11:40 PM
zied012's Avatar
I checked all connectors and there is no wire harness yet, and the fault sometime came sometime no, and when it came, it cause a miss-fire and EPC lamp came ON.
fvuoso
Oct 10, 2023 10:54 AM
pelletman
Jan 2, 2019 08:33 AM
Kebo
Jul 13, 2017 08:55 AM
cyrus89
29
Mar 24, 2015 12:34 PM
