Audi Q7 2009 chassis/wheel vibration around 70 mph
Get an alignment check done and they will look for worn components in the suspension.Don't forget to look at the engine mounts (especially the fluid-filled ones), as you can get some very unpleasant resonances traveling through the chassis from those once they collapse. Look for the easy stuff first, but don't discount that you may have a couple things going on if you haven't replaced any bushings/mounts/end links, etc.
Bottom line, if all you've ever done is replace the brakes/tires on car (completely normal, BTW), then it's time to consider and check for worn components on your '09. But first, just make sure there's no road goo, or other debris stuck to the inside of your wheels because that's a no-cost, easy fix, and it does happen a lot just from normal driving.
I would have the alignment checked, many shops offer free alignment checks. I would also suspect the shock absorbers if they are the originals.
https://static.nhtsa.gov/odi/tsbs/20...22614-9999.pdf
I would also note that all the Audi's I have had are very sensitive to wheels being out of balance and tire pressures not matching compared to other brands. I can usually feel when my pressures are off before the car tells me a tire is low.
