Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Lights do not turn on at night - AUTO lights sensor failure?
Old Mar 13, 2022 | 09:47 AM
rob77mi's Avatar
Default Lights do not turn on at night - AUTO lights sensor failure?
I have a 2007 Q7. Recently the lights do not turn on anymore at night even if the switch is on AUTO.
Initially it was kind of a random failure. I decided to change the gel pad that was visibly old. I bought one on eBay and installed it.
Not much has changed. As I reconnected the wiring to the sensor, it worked. But then stopped working after one or two days. If I disconnect and reconnect the sensor (the one behind the read view mirror), again it starts working but only for a few days.
Do you think I simply need a new sensor? Or is it possibly a different electrical problem?
Any advice is appreciated!
Thanks!
Old Mar 13, 2022 | 07:40 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Scan the car completely and see what turns up before you start replacing parts via the guessing method. You'll need the correct type of scan tool; a VAG (Volkswagen Auto Group) compatible diagnostic scantool. Frankly I'm shocked you don't have one already with a 2007, unless you just bought it and are new to this vehicle. Problem could be in the control module, the sensor, the connector, etc...always, always scan the car for trouble codes/faults. This car won't talk to normal OBD2 scanners...has to be a VAG-compatible, or you'll still be guessing.
Yaemish
Q7 MK 1 Discussion
Nov 19, 2021 07:21 PM
aj25
S4 (B8 Platform) Discussion
31
Apr 30, 2011 07:37 AM
QuattroKid_B7
A4 (B7 Platform) Discussion
Jan 24, 2006 06:17 AM
Gasmanm5
May 10, 2004 05:13 AM
lunamar
Jun 22, 2003 08:59 AM
