Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Intermittent rear camera failure
Old Mar 14, 2022 | 10:48 AM
e-tronDriver's Avatar
Club AutoUnion
Default Intermittent rear camera failure
On my wife's 2015 Q7 TDI (95,000 miles on the clock), we're seeing the rear camera not turning on when shifting into reverse. Initially this was only happening right after the car was started and we're backing out of the garage, but it now occurs more often, not just at startup, but not all the time. When it occurs we hear a few loud beeps from the rear speakers (not the rear obstruction alert, definitely a "you have a camera issue" alert). Is this a common issue on older Q7's? Any ideas on the cause? Thanks.
Old Mar 14, 2022 | 07:48 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
There are several older threads that discuss the parking assist system issues. On our '15 the little car diagram with the distance lines disappeared, but it still beeps for the proximity alerts, and cameras still function normally, except for the 'overhead' view, which is also blank/blacked out if you select it. As I've read, that means one of the acoustic sensors is damaged; just getting started on looking up testing procedure via VCDS.
If you've lost your camera views, that generally means the rear buzzer/soundmaker is bad, again, according to the several reports of the same exact issue. Those owners just bought the rear 'buzzer'/speaker part and swapped it out, and all was back to normal again. Anyways, if you search here, or do a Google search on Audi Q7 park assist failure, you'll get some results to look at.
Landrover007
Q5/SQ5 MKI (8R) Discussion
Dec 26, 2017 10:10 AM
FredL
Q3 Discussion
Oct 22, 2017 04:50 PM
houseofsound
Aug 2, 2004 12:29 PM
Julianjj
Jul 3, 2004 07:49 AM
Marius B
Aug 23, 1999 03:34 AM
