Kerma diesel Tune?
The Kerma tune is not flexible as regards TDI 'modification', so if you think you want to delete now or in the future when things go south, then you'll be buying a different tune...likely from Malone.
Both Karma and Malone tunes have received write-ups herein, so you can search for those threads to get more detail about each type.
Malone puts their tunes on sale around the federal holidays, and definitely at Xmas, which is nice. ECS Tuning (website) is also a vendor for Malone Tunes and other tune shops.
My '10 TDI runs really well (stock emissions w/dieselgate tune) so long as I feed it top-tier diesel fuel and supplement that with Hotshot's EDT (Everyday Diesel Treatment) or similar fuel booster. To be clear, on regular diesel fuel alone it's crap with the dieselgate tune. I also know what I'm missing out on since I drove the TDI with the factory tune on it some years back...very nice indeed! As I have to bench-flash the ECU on my '10, I'm just gonna stick with the Malone Stage 1 for max durability/efficiency, and get off the dieselgate tune, which is garbage on the Gen 1 TDI motor. On cars that can flash via the OBD2 port, the Tunezilla service makes it super easy to DIY this tuning, as well as swap between tuning stages at will.
FWIW, Malone recommends their Stage 1 TDI tune as the best choice for towing use, as the Stage 2 tune is fairly aggressive and makes a lot more heat/boost, etc. Thermal management is key when towing, etc.
On the tunezilla site... it'll definitely tell if there's a flashing compatibility issue, and then provide you the bench-flash options available (ship it direct to Malone or find a local tune shop to do it, etc). As you have a Kerma tune loaded, you should already know if yours allows the flash-tuning via OBD2 port or not...that's simply procedural based on the car's hardware/ECU and not specific to the tune provider.
