Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
do you set battery code every time battery is disconected
Old Mar 15, 2022 | 08:25 PM
rover1man's Avatar
Default do you set battery code every time battery is disconected
Hello,
Audi Q7 2007 4.2 v8. I know you have to set a battery code in VCDS when a new battery installed.
Is it necessary when the battery is disconnected every time?
I have been chasing a power drain problem and have been removing the battery posts when charging the battery.
thanks
Old Mar 15, 2022 | 10:05 PM
Raj800's Avatar
Originally Posted by rover1man
Hello,
thanks
id it’s the same battery I reckon you don’t have to
Old Mar 16, 2022 | 05:48 AM
captain_video's Avatar
No, only when you replace it
Old Mar 20, 2022 | 10:21 AM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Default Battery Drains & Q7s
Hello,
thanks
No, just when you change the battery out, or if you are trying to get the maximum amps charge rate out of the BEM system to 'boost' your older battery recovering from parasitic drains, you can change the last digit in the serial # entered, etc., to 'trick' the car into thinking it's been changed out.
You should have duplicate battery posts up by the firewall, under the 'bonnet'/hood, so you don't need to disconnect the actual battery posts to charge it, as that is going to throw a trouble code out on just about every major system on this car, which then all have to be cleared. So far as battery drains go, by far the most common on the Q7 are the door handle sensors...they go bad on all Q7s. If you will search for "Got Parasitic Battery Drains", I created a thread just to help resolve this specific issue quickly, and without cost...it literally takes about 15 minutes to do all four doors. You should scan the car with a VAG-compatible diagnostic scantool first, of course, which will show you which specific doors have 'grounded-out', and are creating the parasitic drains.
jastreb
VAG-COM Discussion
Mar 31, 2024 06:40 PM
AzJazz
A4 (B9 Platform) Discussion
11
Jul 15, 2023 12:35 AM
Lenny6
New Member Welcome Area
Dec 21, 2019 03:57 PM
ltooz_a6_a8_q7
Dec 25, 2017 10:41 PM
Chrisjharris
Dec 5, 2017 06:04 PM
