Front LED Turn signals
Wondering if anyone has any input and/or a cheap place to pick these up? Thanks.
https://www.europaparts.com/turn-sig...xoC7LcQAvD_BwE
https://www.europaparts.com/turn-sig...BoCn8gQAvD_BwE
I guess I'll just have to take it off when I have a few minutes to get to it and visualize the part number on my car.
I'd sure be using my VCDS to verify if it's really the LED unit vs. something else that has a problem, since those are pretty sturdy assemblies, and verifying the controller, wires/connections. If I had to replace one, I'd be checking for used/recycled parts online via part# search, or a local auto recycler/pick-your-part place, etc. If you buy a new one, then you will notice it looks out of balance on the front of car, since it is so pristine looking compared to the other, lol.I've got a 2010 also; zero issues with lighting, except trying to locate some good reverse bulbs (LED), that will play nice with the Audi voltage monitoring, and removing the stupid license plate bulb on the right side, which has never been out of the car before...little bit jammed/stubborn housing.
Last edited by '10Q7TDI_Prestige'; Mar 20, 2022 at 10:07 AM. Reason: Parts Recyclers and alternative sources
https://deautokey.com/product/921-er...i-q7-2009-2017
The LED turns signals/tail lamp assemblies were the result of the 'facelift' in 2010, and were not an original design item, so my money is on there is a controller unit for the turn signal LED that has gone bad on that one side (mounted in close-ish proximity to it. If I were going to have to remove the whole front fascia to get to anything, I'd likely just get those new kits with multimode built-in that comes with both sides for around $120-$150, so you don't have to worry about the other side going out, and can sell the used one that still works fine for big $$ I like the ones that double as a white, daytime running light, then swap over to the orange for turn signal activation...very modern.
