Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
The "perfect" wheel fitment
Old Mar 24, 2022 | 07:40 PM
b16gsr's Avatar
Default The "perfect" wheel fitment
I had gone back and forth, back and forth on what wheel to do. I was going to have a set built but could not justify the cost for a daily. So I decided to reach out and see if I could find a wheel that fit my specs. I did not want to use any spacers and wanted the "perfect" fitment that would give me the perfect flush fit and look OEM plus. I had the local shop lower the Q with H&R springs and then dial the alignment in, as well as a set of motor mounts. I simply love the way it drives after the springs. The OEM wheels were not going to work, and I wanted to stick with a 20" wheel. So after a long search I found the elusive wheel.
20x10 TSW Gatsby
295/40 Michelin Latitude Pilot Sport N0
H&R springs
It sits absolutely perfect for me now.
Old Mar 25, 2022 | 05:36 AM
cvillebimmer's Avatar
Those look fantastic! Do Audi center caps fit?
Old Mar 25, 2022 | 06:05 AM
Kei78's Avatar
Just wondering on 10” wide, what offset are the wheels?
Old Mar 25, 2022 | 11:32 AM
YotoWerks's Avatar
That does look fantastic! I am running 19X11 wheels with 285 rubber and it too fits absolutely perfect. These cars benefit form having some rubber thickness around the wheel with the corresponding open space around the tire to the fender. Most people dont get that balance right and it looks like the SUV is all lifted up and quite frankly look like aftermarket stuff.
I love when I see some good 40 series rubber on 20 or 21" wheels.
Your car looks like it can use some S-Line fender extensions which you can buy on ebay for about 180$ for all 10 pcs.
Mine sits on 19x11 with 285 45 tires and offers the absolute ride comofort. Fitment is near perfect too with 20mm front and 25mm rear spacers.
Old Mar 25, 2022 | 05:05 PM
b16gsr's Avatar
yes you could fit the oem caps. I like the TSW.
35mm
they like the rubber. Yours look good too. I do not like spacers as I will be towing my 911. Picked up the new trailer today.
Old Mar 25, 2022 | 08:31 PM
jbain2's Avatar
I need new tires on the Q I just picked up. I am definitely going 295/40. The extra meat on the sidewall is a must.
Nice wheel choice and setup OP!
Old Mar 26, 2022 | 04:35 AM
b16gsr's Avatar
Unless you have a 10” wide wheel a 295 is not recommended.
Old May 25, 2023 | 08:09 AM
@b16gsr - Did you need hub-centric rings for these? I just picked up a set of these, and the shop called to inform me that the hub bore is slightly larger than my stock 21" peelers. They said that they think it'll be alright without them - we'll see, I guess!
 Pouria Savadkouei
 Michael S. Palmer
Old May 25, 2023 | 08:29 AM
urs6_ma's Avatar
I put a set of C6 wheels on a C5 allroad once...the hub bore is quite different between the two and it was quite amusing.
I would not count on five bolts to center a wheel. That's not their design...they provide clamping, rather than positioning. The hub provides the positioning.
Everything *might* be fine. Or not. I wouldn't do it.
Old May 25, 2023 | 08:35 AM
I'm with ya! I just ordered these: https://www.463industries.com/access...ngs-841-to-716.
It was silly of me to compare hub sizes in the first place!
