Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Audi Error P27550 - Please help :)
Old Mar 25, 2022 | 04:09 PM
kizza1234's Avatar
Default Audi Error P27550 - Please help :)
Hey guys have a small issue.
Getting a p27550 error code from my OBDeleven on my Audi Q7 2011 TDI, with error in the car being Transmission Fault limited functionality.
Figuring it was the transmission coolant valve or plug as I have seen in this forum so I replaced that and checked the plug and cable which was good. Infact the old valve didn't see to have any issues.
But still getting the error.
One note is the transmission pan has a dent in it as well which I haven't noticed before, I have read perhaps a transmission filter above the pan could cause this kind of error?
Any help would be amazing guys!
Old Mar 25, 2022 | 06:40 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
How many miles, what are the symptoms, have you ever had the tranny serviced, are their any other error codes, how many times has this trouble code occurred, is it triggering the MIL indicator on the dashboard or is it just in the background, etc., etc.
Use the Google search link provided inside your OBD-Eleven readout...that's the pretty (scripted font) g on the right hand side of the screen when you are looking at the error code...save you some time it will. Also, you bought the wrong scantool if you really want/need to be able to DIY and fix anything more than a sniffle on your Q7...that's the territory of the Ross-Tech VCDS. A P-code format error code is rather generic and will only get you so far on the Q7.
From a quick key-word-search, the first thing to show up is check the fuse and/or relay linked to that transmission cooler valve, then there's the temp sensor itself, etc. If you did take a hit underneath, a wire or sensor may have sustained damage as well...always start with the low hanging fruit.
Old Mar 25, 2022 | 07:56 PM
kizza1234's Avatar
140k Km
Recently had an engine swap however, and the error appeared after the swap.
Are there any particular parts to look at for this kind of error? No other errors in system other than this 1 error.
Old Mar 25, 2022 | 07:57 PM
kizza1234's Avatar
Audi Q7 2011 3.0 TDI
Old Mar 25, 2022 | 07:58 PM
kizza1234's Avatar
There is a check engine light on dash specific to this transmission error, but warning message says it is ok to drive but with limited functions.
Old Mar 25, 2022 | 09:38 PM
kizza1234's Avatar
Where would the fuse loaction be for a 2011 Audi Q7 TDI, i looked at both Passenger and driver fuses boxes, but there are not fuses there for any valves or sensors.
Is there another fuse location I can have a look at?
Old Mar 26, 2022 | 03:40 PM
So, engine was swapped, then did you see this error almost immediately (related to the engine replacement), or was it significantly later?
This car has like 6 fuse panels; under hood/bonnet, both sides edges of front dash, under the dash, next to the battery (under front seat), and in the right rear side of car, there are a couple more hidden behind a trim panel (with the power outlet at bottom of the panel in cargo area). You can look up the diagram for location of fuse in owners manual, or it was just posted to a recent thread on here as a resource for someone else tracing problems. I'd be googling if you don't have the manuals for car.
Old Mar 26, 2022 | 03:42 PM
kizza1234's Avatar
I've had a look through fuse diagrams but cant find any mention of the fuse for this valve? Is there perhaps a differnat set of name it would be under? Thanks so much BTW!
 Pouria Savadkouei
 Michael S. Palmer
TTKat
New Member Welcome Area
Jan 4, 2021 10:48 AM
VR6eric
A6 (C7 Platform) Discussion
Apr 13, 2020 12:47 PM
Ken Dandridge
A4 (B7 Platform) Discussion
Jun 23, 2018 08:02 PM
Mitchelchevy
Audi allroad
Jun 23, 2015 03:06 PM
tracto
Audi A3 / S3 / RS 3
Sep 14, 2012 07:30 AM
