Overfilled oil now rattles 14 q7
The issue of the rattle I do not think is related to an overfill as the oil was not frothed.
Basically at the juncture of two pieces of splash guard is where the oil drain plug/engine oil pan is located, so pretty close to the front of the car. Behind that you are going to have the transfer case, which doesn't hold much fluid, and then there's the transmission sump pan and drain towards the center of the car that hopefully you didn't touch.
That would lead into the next question: Did you use an oil meeting the extended life requirements and VW oil-spec requirements for your car? Putting the wrong oil in this car is also likely to create problems, and if you did go over by 4 quarts, which would lead me to believe you did drain from a different location, it's likely that you did some damage to internal seals, etc., when you drove it.
Proceed with extreme caution.
