Axle shaft replacement on 2019 Qy w/21k miles?
I'm new here, just purchased our first Audi - a 2019 Q7 Prestige trim with 21K miles. We purchased through Carvana and they delivered last Friday - on very first test drive, my husband heard a knocking noise. We called Carvana, took it to a nearby repair facility who then referred us on to Audi. Audi is saying the rear passenger axle shaft needs replacement and the differential may need to be sealed - both will be covered under warranty.
My question is this - is replacement of an axle shaft at 21k miles indicative of a poorly maintained or recklessly driven vehicle? The car is gorgeous and we'd like to keep it but we're still in the return window with Carvana so could opt to return and find something else. We're not terribly car-savvy so would be grateful for guidance from you expert Audi owners!
Thanks in advance for responses!
If it was an off-lease car, then I would be surprised the original Audi dealer did not just fix it up and sell it themselves -- with today's supply chain problems and lack of cars to sell. Therefore I suspect the previous owner decided to get rid of it fast through Carvana because of the axle problem. I am not sure why warranty repair was not claimed before that.
Were there signs of curb rash on the wheel? Signs of leaks around the differential?
With the 2016-and-up generation of Q7 (called Mk-II for 2nd generation), there are control arm bushing problems, engine mount problems and water pump failures (both 2.0T and 3.0T). The rear coil springs can break on some cars. Each would be around $1500-2000 to fix. 3.0T can have oil consumption problems nearing 100K miles and the engine may be a goner. The transfer case (aka center differential) can also develope a rumble but can often be resolved with an oil change. You can read up on the threads.
You might want to look into an extended Audi Care Platinum warranty (up to 10-years 120K miles) if you decide to keep the car, but that may only be available as CPO.
https://www.audiworld.com/forums/q7-...ilure-2916483/
https://www.audiworld.com/forums/q7-...miles-3003955/
https://www.audiworld.com/forums/q7-...ition-2863609/
https://www.audiworld.com/forums/q7-...umble-3003251/
https://www.audiworld.com/forums/q7-...pring-3036276/
Audi care plans:
https://www.audiusa.com/content/dam/...O-Brochure.pdf
