2007 Q7 3.6L Front Brake Pad / Rotor Replacement Question
Here is a Touareg tutorial thread on the front pads and rotor replacement. This is what my caliper looks like. It says 13/16" socket (depending on the SAE socket's tolerance. 21 mm would be the correct fit as all bolts are metric) for the front caliper bolts. 13 mm for the pad pin (single pin version). Get new caliper bolts from the dealer. I used new bolts each time and torqued to spec, even if these bolts are not torqued-to-yield with an angle turn. This thread says 270 Nm (199 lb/ft).
https://www.clubtouareg.com/threads/...updated.83346/
The rear caliper uses a triple square bit. I do not remember the size, but this thread says XZN16 (16 mm triple square in post #13) and torqued to 180 Nm (133 lb/ft). The 17" rotor with single pad pin does not require a socket to remove. A metal clip retains the pad pin.
https://www.clubtouareg.com/threads/...e-disc.194369/
Changing the rotor requires you to adjust the parking brake shoes (even if you do not replace the shoes), because the drum sizes may be slightly different.
https://www.clubtouareg.com/threads/...-shoes.194401/
Triple Square bit set:
Torx bit set:
Pads and rotors on Rock Auto: https://www.rockauto.com/en/catalog/...brake+pad,1684
Triple Square bit set: https://www.amazon.com/LEXIVON-Tripl.../dp/B07M6884DY
Torx bit set: https://www.amazon.com/LEXIVON-Socke.../dp/B07M9ZF35W
