Failed oil consumption test 2017 q7 3.0t premium plus
My Audi Q7 2017 3.0t has been plagued with issues after the first year. It had two cracked cylinders under warranty replaced. I should of traded the car in at that very moment. The dealership assured me this was not normal and just a defect within the metal and not at all common. Upon placing the engine back in they broke several additional parts (all covered by the dealership).
Sometime later I noticed my q7 slowly requiring more and more oil between oil changes. I told my Audi dealership’s service department that I suspected it was using an unusual amount of oil. I was brushed off and reassured it’s normal and it’s a high performance engine, but that my car was in great shape. I’ve never missed a service or the recommend maintenance.
Well, several years later at 120,000 miles (all highway) I paid for the oil consumption test. It failed at no surprise to me. The service department told me my engine is shot because, there is no repair kit available for an engine of that years model. It’s basically too new to fail. I attempted to reach Audi customer care at the dealerships direction but, couldn’t stomach the three and half hour hold time.
Suggestions?
That said, you've done everything right as an owner, and you have a valid case with Audi. There was a recent thread in regards to an owner with '17 had the engine suddently seize up from a broken spark plug tip; the car had only ever been serviced by Audi, and all services were completed. Her dealer said pay up or F-off. She appealed her case to Audi North America...the dealer doesn't care about you, BTW, and Audi N.A. extended a 'good-will' offer to assist her with replacing the engine for about $8k (USA$), which was basically their cost. The 'normal' price for a new engine swap out was going to run approx $20k, according to her post, so your dealer may be blowing some smoke up your pipe with inflated figures. It's not cheap, but it's certainly not $30k either.
To be sure, you are long outside of any warranty coverage unless Audi dealer has replaced stuff/parts within the last year, as new parts get a new part warranty, etc., but as this was reported prior, and you paid for the test to determine the issue when your dealer repeatedly told you there was no issue, you have a valid case.
When I called Audi N.A. to file a complaint recently, I chose their customer service prompt, and after a short wait it offered me a callback at my number, so I didn't have to wait on hold. Take that option, and go about your day with your ringer turned up on high.
, and you can't go buy any kind of a comparable replacement in the current new/used car environment; even the beaters are expensive, LOL. Be patient.I just had one in for warranty repair of EGR coolant leak where the tech falsified the diagnosis details, said it was not warranty covered, and recommended a generic, oil-cooler plate reseal service, which actually does remove all the EGR cooling system components, but isn't focused on resolving a leak in the EGR cooling system circuit. The explanation for selecting that as the service was that in removing everything to do the oil-cooler plate reseal jobber (seals getting damaged by the leaked coolant), that it would all get the stink-eye inspection before going back together, and they would locate the coolant leak that way, etc. As I took it in for a warranty repair, I was happy they were going to do the reseal jobber where the coolant had been leaking on the cases, and eroding those seals, in addition to correcting the coolant leak source. I can't say for certain it's the EGR Cooler or the EGR Coolant Diverter Valve that's the leak source, but those are the most likely suspects.
I got my car back after a month, with nearly three weeks time wasted solely on the warranty dispute process with the dealership. The worst part; after failing me at every single customer touch-point, they then failed to repair the coolant leak it was in their shop for; how does that even happen at such a highbrow dealership, Audi of McKinney, TX? The prior dealer's shop I took it to (Audi of Grapevine, TX) couldn't even find a coolant leak, although you could easily smell it when it was hot, the reservoir showed it was losing coolant, etc., and they told me to come pick it up. Now, that's after my directly telling them where it was leaking from, how to visualize it, and doing everything except for 'X marks the spot' in marking paint on the engine for them. I mention these recent experiences only to illustrate both the ineptness of the 'technicians' employed by many Audi dealers at troubleshooting, and the fact that they often times manufacture their own 'truth' about your car's diagnosis/prognosis, to ensure it aligns with whatever lines their pockets, or is in their own best interest, not necessarily the customer's or the car's best interest, even when it's covered by warranty. I can't explain why they treat their customer's this way, but that's been my experience. I've been to three Audi dealerships with our cars, and rarely has a warranty visit ever been calm & relaxed, or a non-event, like it should be.
Last edited by '10Q7TDI_Prestige'; Apr 5, 2022 at 01:03 PM. Reason: Dealer Name & Shame ;)
Audi sold 25,363 Q7s in the US. I am not surprised there is no interest in providing good support. Just buy another one I suppose. NOT.
https://www.goodcarbadcar.net/audi-q7-sales-figures/
Rather than jumping on the "Let's just replace the entire engine that runs perfectly fine" bandwagon, which is soooo typical of how Audi corrects problems, let's take a step back, and pause a moment to embrace and fully understand the 'normal' causes of accelerated engine oil consumption, especially as pertains to higher mileage vehicles. You don't DIY your services, so I'd suggest you find a good local mechanic shop with excellent feedback on fixing German cars.
I present you the following links to moderately entertaining and mechanically sound information that may help you out. Certainly you'll be better informed, as will some of our DIYers. Please watch both videos, as they present different known issues that result in high oil consumption:
Why is my car losing oil but no leak?
A defective PCV valve can often cause your car to lose oil but no leak or smoke because it prevents the natural flow of oil. Extra pressure creates oil waste from cylinders. In consequence, you will need to feed your car more oil than its natural demand.
