Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Gen 1 body compatibility
Old Apr 3, 2022 | 07:37 PM
Fin Reaper's Avatar
Default Gen 1 body compatibility
Will a 2013 hood and rear hatch fit on a 2007 Q7? I understand they're both Gen 1, but the 2013 has an appearance package.
Old Apr 4, 2022 | 09:11 AM
testarossaguy's Avatar
As far as I know.....there is no difference....they should work fine with no issues.
Old Apr 4, 2022 | 09:28 AM
Pothole5000's Avatar
If you click on the vehicle fitment tab for the part number it shows that this fits from 07-15.
https://www.genuineaudiparts.com/oem...QtMmwtdjgtZ2Fz
Old Apr 4, 2022 | 04:10 PM
Fin Reaper's Avatar
Thank you guys, I appreciate it.
Old Apr 4, 2022 | 05:38 PM
B6-3.0L's Avatar
The rear hatch is different for 2010-2015’s. The cutout for the taillights is a slightly different contour at the lower inside corner. The opening for the light connector is a different shape too. If it comes with taillights, then no big deal except for the control module. The 2010+ facelift models have a revised module for the LED taillights. The module needs CP removed to function completely.
Old Apr 6, 2022 | 04:07 AM
Thank You so much B6-3.0L for pointing that out about the rear hatch....!
Old Apr 7, 2022 | 03:14 AM
B6-3.0L's Avatar
No prob. It’s barely noticeable unless your looking for it. I found out when doing a facelift taillight retrofit. It requires slight grinding of the new light housings/lens in order to fit the ‘07-‘09 tailgates.
kcosh
May 29, 2012 05:36 PM
Greg PAW - MS
12v V6 Discussion
12
May 15, 2004 10:47 PM
millenniumrocket
Auto Detailing Discussion
Apr 12, 2004 02:37 AM
foberg34
Apr 11, 2004 03:11 PM
