2007 Q7 3.6 1st scan results ross-tech hex-v2
Here is the txt file results
Any help is appreciated
What I've noticed is that the side mirrors don't move with the controller, the display on the middle of cluster is blank/black, i have to replace the blower motor for hvac and change the cabin filter. I'm also going to replace the spark plugs and coil packs.
https://www.audiworld.com/forums/q7-...ndles-3031705/
Since you are asking about batteries in the other thread, I would get a new battery in and coded correctly. Delete all these faults, then rescan and see what comes back. A lot of these might not.
Scan the engine module. I think Group 140 Field 3 (or maybe it was 141) and see what high fuel rail pressure you have. All 6 cylinders misfiring has got to be poorly maintained by the previous owner or something other than the ignition system (like with the high pressure fuel pump HPFP). You can also pull the plugs and see if they are all carbon fouled.
Our Sirius radio unit was a piece of junk, failed early in ownership. You have 14v running, so it might not be a battery voltage issue. Get a fiber optic loop and bypass that junk from the MOST (Media Oriented Systems Transport) fiber optic bus. IMO, MOST sucks.
You have the 0AT ZF 6HP19 transmission. Nice!!!!! Love ours. Your Q7 must be a Premium model. Others get the Aisin 09D.
For J258 control module in instrument cluster, see https://forums.ross-tech.com/index.php?threads/29560/
The brake lamps problem remove the bulb and see if the contacts are melted. You may need to get new harnesses. I think there were some manufacturing defect from the factory.
Resolve the door handle errors, reprogram the BEM system/check the battery date code sticker (on side of battery) so you know for sure prior to hauling the battery out of the car, and charge it fully. You might be surprised; I was absolutely floored when mine tested good after all the drama and low voltage error codes.Last edited by '10Q7TDI_Prestige'; Apr 7, 2022 at 04:25 PM.
Danger, Will Robinson! Proceed with extreme caution.
Replaced the hvac blower motor, spark plugs/coil packs, taillights w/ new harnesses...still have to do the door fix and have my instrument cluster repaired. Not sure what the hatch failure is, it opens and closes just fine. Also, the warning lights on the side mirrors work fine and blink if I change lanes "too early."
