Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Left rear door will only open from inside 2007 Q7
Old Apr 17, 2022 | 04:12 PM
bg_2007Q7's Avatar
Default Left rear door will only open from inside 2007 Q7
My left rear door will only open from the inside. So, I know the latch works. Does this mean the cable that connects the outside handle is probably disconnected?
Old Apr 21, 2022 | 02:29 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Default Fun with Door Handles
Can't say for sure on Q7, but usually this means the door handle itself is going to have to be replaced, as the little plastic bit on the big end of it serving as anchor to the actuator cable has broken off. I've had that happen twice on another car with a similar 'pull to open', cantilever style handle setup. On that car it was the passenger side doors front/rear, and I had a couple family members that were exceptionally fond of yanking really hard on those 'pull-to-open handles and then slamming the doors. No issues like that on the driver's side of that car, but then they didn't get in or exit on that side either. Anyways, my money's on that little piece being broken off the back side of the door handle, which renders it useless for opening the door.
Old Apr 21, 2022 | 03:03 PM
bg_2007Q7's Avatar
Thanks, I will put it on the bucket list. Not a huge priority now.
Old Apr 21, 2022 | 08:44 PM
bg_2007Q7's Avatar
Just curious, do the replacement handles come painted? Or is that another extra charge?
Old Apr 22, 2022 | 07:50 AM
Pothole5000's Avatar
New ones come unpainted. You can gamble on used ones off eBay, but they don’t always list the paint code correctly, and the sensors will probably be dead.
Old Apr 22, 2022 | 08:22 AM
bg_2007Q7's Avatar
Thanks, I will have to put that off. I imagine the body shop would have to blend the handle into the door. Sounds expensive...
arp2nr
Q7 MK 1 Discussion
Jul 28, 2009 12:42 PM
Argelius
A4 (B8 Platform) Discussion
10
Jun 5, 2009 07:19 PM
iconoclast
Aug 4, 2008 06:04 PM
Mica
Jul 6, 2007 07:36 AM
Oo.et.oO
May 1, 2006 11:47 AM
