Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
How to re-attach plastic front seat backing?
Old Apr 17, 2022 | 05:26 PM
bg_2007Q7's Avatar
Default How to re-attach plastic front seat backing?
Are there clips for the plastic piece that attaches to the back of the front seats, or was it glued on? Either way, mine have separated over time. What is recommended to re-attach the seat backs?
Old Apr 18, 2022 | 02:53 AM
Cboogie's Avatar
I used velcro with a sticky side.
I cut into small pieces and removed the glue backing and placed around the back of the plastic
.then pressed them into place over night with the help of the back seat head rest.
I did not want to permanently glue it shut. You never know when you might need to get in there.(was thinking about running monitors for a while)
Old Apr 18, 2022 | 03:29 AM
bg_2007Q7's Avatar
Velcro is a good idea, thanks.
Old May 6, 2022 | 10:01 AM
das1997's Avatar
This is a great idea, mine has started to come off as well.
Old May 6, 2022 | 10:09 AM
bg_2007Q7's Avatar
I had to switch from the heavy duty 3m velcro to 3m vhb double sided foam tape. For whatever reason the velcro won't stay stuck to the plastic. The vhb is much stronger and seems to be holding well.
Old May 8, 2022 | 06:14 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Bought two types of the super-heavy duty, outdoor rated, velcro style hook-n-loop type at Home Depot...pretty reasonable cost; holds up to 15lbs per strip and handles abnormal surfaces; on my To-Do list, so we'll see tomorrow. I had prior tried to apply a sealer product to it similar to RTV; didn't hold up.
hisself
Q7 MK 1 Discussion
Sep 18, 2021 01:43 PM
genxhunter
Q7 MK 1 Discussion
Dec 26, 2019 01:05 PM
ChappyConcord
Q7 MKII Discussion
Nov 5, 2019 03:47 AM
RussB
10
Feb 4, 2006 06:43 PM
softaildeuce
Dec 30, 2005 11:35 PM
