Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Audi Q7 4L foult codes
Old Apr 19, 2022 | 05:03 AM
Preben's Avatar
Default Audi Q7 4L foult codes
Hi,
I`m newbie here, but I have alot of issues with my Q7 4L - 3.0 TDI - 2007 model.
Attached is a full scan from VAGCOM, I have tried to replace the throtle body, but engine still goes into limp mode, but only when engine is hot and you startup engine again.
Its typical when i have drived to a friend, stayed there for a half hour and when I startup its in limp mode. foult code wont be erased before engine is cold again. Then everything works normal again, with or without clearing foult codes.
Rear parking camera went also completely black, so this doesnt work either. I am unable to connect with several modules in VAGCOM. I cant re-code my key due to unable to connect with central lock mudule. Can someone please check attached VAGCOM scan and give me your oppinions of what you think i should start replacing or look in to?
Appriciate all feedbacks
Thanks.
BRG. Preben
File Type: pdf
Old Apr 19, 2022 | 07:25 AM
Mxeryus's Avatar
Lots of error messages, some unrelated to each other but still quite a list.
Although there is no fault from the battery, I would check the battery first with a external battery tester.
Old Apr 19, 2022 | 01:19 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Agreed on the battery. I'd also reset the whole mess, drive a bit, and see what comes back.
Davemay123
1.8T Discussion
Feb 6, 2017 08:47 AM
MN1990V8
May 22, 2008 04:03 PM
Paul_A8
Oct 5, 2003 11:45 AM
GDJT Allroad^2
Jun 26, 2003 06:04 PM
ShokWaveRider
Jan 14, 2003 07:12 AM
