Front blinker LED question
Thank you
As the other member said, you won't get that from an original Audi turn indicator, but it is available aftermarket for a 2015 Q7 on places such as Aliexpress..if you are really interested, do some research and make sure it fits properly..check out the link attached..copy the link to your browser..
US $189.35 46%OFF | 1 Pair DRL Dynamic Turn Signal Function Waterproof 12V LED White Yellow Daytime Running Light For Audi Q7 2010-2015
https://a.aliexpress.com/_mMFog4O
As stated above, those turn indicators are single-purpose amber lights, so you won't get what you're after from Audi. I'm pretty sure Audi designed it this way to comply with lighting regulations without having to make the DRL turn off when signaling (the turn signal is far enough from the DRL to avoid that rule). Having the signal be dual amber/white removes this advantage and introduces new control / de-conflicting requirements.
Your car is functioning as designed, and you are just going to create headaches and more expense for yourself by tearing into this particular car on a whim. Are you aware the existing DRLs embedded in headlamps are adjustable for brightness level output, and of course they can also be turned off completely.I also like those multifunction front turn signals, but that'll be a project for whenever they go out on one of our cars, and not something I elect to swap out 'just because'. You might want to think about putting some $$/time into your driveline fluids that have never been changed out...front/rear differentials, transfer case, transmission, and doing a level-reset on your car's maintenance with engine oil, filter, fuel filter, air filter, etc. Check the brakes for rotor 'dishing' and pad wear, etc. These are the things you do after purchasing a used Q7. Oh, and don't forget to screen for underbody oil leaks and corrosion/rust. The splash guards under car catch most anything that is leaking in their sound insulation, so often you don't know there's a leak unless you look.
