2015 TDI current draw
Battery has been tested good and was replaced by PO in December. Spare well is bone dry.
https://www.audiworld.com/forums/q7-discussion-112/need-bem-code-h8-agm-battery-3015231/
It's always the door handle sensors grounding out the circuit and often in combination with the car not being 'coded' to reflect the battery was changed, so it will throw the full amps at it, so you can get a dual effect going on; the more bad door handles, the greater the drain, and the alternator won't keep up if the battery didn't get coded when changed out. If you got multiple door handles grounded, it won't keep up anyway since those are 24/7/365 parasitic drains. The fix is easy though on door handles and the coding. You'll need a VAG compatible scantool, preferably VCDS, but many others can also perform battery swaps on this car...just not an OBD2 type, as it doesn't speak German. See the links above for direct access.
My only hesitation is that I don't have any door codes except an implausible signal at the right rear. Weird?
Edit: I stand corrected - looked through a scan from this afternoon and found short to ground on both right doors. Doing all four lobotomies tomorrow. Not enough space in the garage to swing the doors fully open.
It's a personal choice obviously, but I like the features that sensor supports, so I'd only do the two that are bad, if it were my car... especially since both the driver's side still function normally, which is mainly what you want; it's a nice feature to have the walk-up recognition /unlock, etc. I kept my working door sensors active on both our cars primarily on the basis that it is so quick & simple to disconnect them. I also found the lock/unlock buttons on the two handles (passenger side) on our '15 still function normally, even though the proximity sensor circuit was snipped on both those doors, which is also pretty awesome to retain those, for convenience.
Kinda like driving around with a ticking time bomb. Failure rate sounds like it's near 100% for these things - it's not "if" but rather "when"
Its annoying as heck that the damn battery keeps draining I keep mine on trickle charger hardwired to the battery in the winter and it has helped but its time to fix it for good.
Still need to verify that the battery is coded correctly, but hoping to avoid dead battery syndrome for a while anyway...
Great info in this thread and the linked threads. My hat is off to 10Q7TDI.
The only issue is that it's an Interstate Battery, not OEM. I re-coded the BEM using a code for a similar amp battery, and I'm not sure if that's the issue. Debating just buying a dealer battery so I know I'm starting with a known good.
Thoughts?
On VCDS, and likely on other systems as well, you can view the Gateway Module (#19), and be able to see not only the output from your alternator, but the battery aging, current capacity in amp hours, % charged, and also the amount of battery drain occurring, and lots of other relevant info.
You've done the handles with fault codes, and they are now shown as 'open circuit' faults, so correct the BEM coding and go observe the charging rate, state of charge on battery, etc., via VCDS or whatever you've got. If you reset BEM correctly, the charge rate should go to 15 amps with car running, air on, etc., and you should be able to watch the numbers on your battery improve rapidly from that point. As always, the cables to battery need to be in good shape and secure. The little lead that plugs into the battery cable for monitoring (easy to forget to replace) is for the BEM system. Some members have simply removed that plugin, which stops the feedback loop/BEM system from managing the battery, so it defaults.
