07 Q7 Strut / Shock Replacement Parts Question
I used aftermarket KYB ones. IIRC SB104, about $10-12 a kit of bellow and bump stop?? These are not OE fit and will not click into the upper mount as the OE ones do. I do not remember if the bump stops fit the rear shocks with a smaller rod diameter, I think they do for the fronts.I placed the new bellow between the bump stop and the mount, the bump stop holds it up nicely. Or you can assemble the KYB bump stop according to their instructions, pointy side up and the bottom into the groove in the bellow and use it that way. I just reused the old bump stops. I believe the OE bellows are about $70 a piece and bump stops about $40 each. A good laugh anyway. What a joke. However you can opt for OE ones if you want exact fit.
Remove the white plastic lower bellow holder (or whatever you call it) from the original Sachs shocks. Bilsteins came with smaller black plastic covers. Lightly hammer to seat them onto the new shocks. The original ones will not fit the slightly larger Bilsteins properly. Do not use both together.
I used new Lemforder sway bar links front and rear, but in retrospect I could have just reused them. I got all new mounting nuts and bolts for the shocks.
This would be a good time to replace the upper control arm or at least the bushings. I used TRW control arms. I have not done anything with the lowers yet, trying to decide just the two inner bushings or new Lemforder control arms. The inner rear hydro bushing fails often.
My rear control arm bushings were so hardened that it was difficult to pry them down to remove the shock assembly. I had to loosen the two upper arm mounting bolts on the inner side. If you do that pick up new nuts and bolts from the dealer. These are torque to yield, just like the large mounting nuts and bolts for the shocks as well as the upper control arms.
Some videos helpful to me:
https://www.audiworld.com/forums/q7-.../#post25689112
I dont have the equipment to do this job myself, so I am going to have an Audi/VW shop install them. I will get the mounts, control arm bushings, dust bellows and nuts/bolts.
Also, if you have aluminum lower arms, then the rear hydro bushing is the larger diameter one. I think it was 72mm instead of 60mm or something like that. Your dealer should be able to pull the correct part numbers using the VIN number. If you purchase Lemforder in the aftermarket I believe in my case it would be the 7L0407182G and NOT the 7L0407182E.
Control arm bushings:
https://www.rmeuropean.com/Make/Audi...?catalogID=016
Inspect to see if the control arm ball joint boots are in good condition and not leaky grease before you opt for bushing replacement vs getting new control arms. The front lower camber adjuster bolts have a habit of seizing to the arm in salt belts. I would only use Lemforder (or TRW, which owns ZF and Lemforder) lower control arms if you do need new arms.
Also, my 07 Q7 is a 3.6L Premium model. Do you think they put the aluminum lower control arms on it with the larger bushing?
I really hope the control arm ball joints are intact. I didn't realize how much control arms cost. I guess i need to get under there and take a look.
My front upper control arm bushings were torn and squeaking. After I removed the upper control arms I found that the ball joints and boots were still in good shape. This is quality control arm Audi used! According to the RM European catalog, I believe each upper arm takes TWO 7L0407077 bushings.
Please verify the correct fitment with your dealer and VIN number. Upper control arm, TWO each side of this:
https://www.rmeuropean.com/Products/...G69-V1001.aspx
https://www.audiusaparts.com/oem-par...hing-7l0407077
Lower control arm, ONE each side of:
Inner rear hydro bushing:
https://www.audiusaparts.com/oem-par...ing-7l0407182g
Inner front solid bushing:
https://www.audiusaparts.com/oem-par...hing-7l8407183
My outer front solid bushing (where the shock mounts to) appeared to be in good shape, and I do not plan to replace this one if I do the bushing-replacement. But this is it:
https://www.rmeuropean.com/Products/...292-V1001.aspx
https://www.audiusaparts.com/oem-par...ing-7l0412333a
Clearly the dealer prices are ridiculous. A new Lemforder arm would be more cost effective. LOL
TRW front upper arm (out of stock):
https://www.rmeuropean.com/Products/...G80-V1001.aspx
Lemforder front lowers:
https://www.clubtouareg.com/threads/...-bushes.63300/
https://www.clubtouareg.com/threads/...numbers.80445/
This 2007 Q7 lower arm DIY. Looks like he had aluminum arms but put in new steel arms!! That is going backwards from what DIYers do (going from steel to aluminum).
Please verify the correct fitment with your dealer and VIN number. Upper control arm, two each side of this:
Lower control arm, two each side of:
Yes the oem part prices are crazy expensive...
While it's nice to replace lots of the hard to reach stuff when doing the struts, get a professional eval done if you don't really know cars that well, or you may well be spending the kids inheritance or your own retirement fund before your done with that 'snipe hunt'. The main things are going to be the known wear parts/bits, and when struts are off you change the strut mounts, replace the protective dust boots and urethane bump stops...those OEM bump stops are peanuts from the right site, btw, I've seen them listed...probably was Rock Auto. You can pay a lot of $$ for just about anything, but you don't have to; just be smart about where you shop and price shop by part# search on the internet. I like to look at Rock Auto as it gives you a nice range of pricing option for diff quality parts, and you'll see TRW and Lemforder, etc., there too. The main thing is you get a get a good 'feel' for what things should cost, and like I said, often you can get tremendous deals on Rock Auto via close-out /overstock purchases, etc., and get exactly what you need.
Just bought a complete new air compressor and valve-block setup for air suspension from there, and got a great deal; trust me I shopped hard on that one, as those parts can be very expensive if you don't.
Good luck; this is not something you can do over the forum so much except for the advice bit. Your car is your car and it's in the condition it's in, and we don't know what that is, what your level of DIY skills is, or what you will find if you dive into it yourself. Get a professional inspection if you need one, so you'll know what requires servicing besides your struts, and not be spinning your wheels. Spending $100 is a really good investment, if you don't know what really needs doing on your car.
