07 Towing package
Be sure to verify condition of the harness side hook-up for any corrosion, clean contacts as necessary (electrical cleaner/brush) & regrease (waterproof electrical grease) prior to securing it onto the trailer plugin port, etc. Unlikely the factory ball hitch is with the car still, as it has the heft of a boat anchor, but the factory hitch is of the heavy-duty, solid shank type. It's waay overpriced via Audi, but you might find the OE/OEM part or an aftermarket version reasonably priced via part # search. Pay attention to the specs of the OE ball hitch if looking to the aftermarket for one, as they come in every length, drop/rise, and ball size imagineable...easy to get it wrong if you are new to towing. There are also guidelines for the hitch on sticker attached to the receiver end that peeks out behind car.
