When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Ok so my battery seems to die when I lock my car. I also have to keep my car unlocked and have to push the unlock button when getting out of the car for the car not to die. Its very weird and do not understand. I also have a problem with my blinkers. any ideas?
You've not provided any info about your car's year model, engine, mileage, how long you've owned it, etc., so basically all I can tell you is the OE batteries usually last 6-8yrs. Door handle ground faults are very, very common on the Q7, and cause battery drains to occur 24/7/365 once they start. Multiple bad/faulted handles means faster battery drain. Battery voltage is very, very important on this car, and will create myriad odd symptoms in the car itself where items don't work, or things occur that you've never encountered before. If you replace a battery on this car, the job's not done until you've told the car you changed the battery by updating via scantool that you changed the battery. There is a dedicated thread to these topics you can locate by searching on the title of this response.
You will need to get your car scanned fully. If you want to DIY almost anything on this car, then you need a VAG-compatible diagnostic scantool. VAG=Volkswagen Auto Group. The Ross-Tech VCDS system is the best for this car for DIY. To simply read codes to help basic understanding and troubleshooting, an OBD-Eleven basic module (without any annual 'upgrade' subscription) is the clear choice for entry level use.
