Cranking amps drop
starter replaced
battery replaced
Saw somewhere people installed a device under hood to the terminals to give extra amps
2013 Q7 TDI 3.0
Anyone ?
Known issues: Not resetting the BEM system correctly and verifying it has reset/is charging at full/max voltage (15 volts), etc., when called for based on battery condition, as viewed in the Gateway channel (channel 19, or where you locate same info on yours may possibly differ in Australia market). The door handles go bad internally (prox sensor), and create parasitic battery drains...there will be trouble codes/faults in car related to this when scanned with a VAG-compatible scantool. Resolve this by snipping the power wire at terminal #15 on the harness that comes out of the door (see thread on parasitic drains for exact instructions, pics, etc.)
So, to recap. This car is an energy hog; you want a battery with as much storage capacity as possible; the OE capacity is 110 amp/hours. This car requires you to reset the BEM system when the battery is changed. Failure to recode the car's BEM system will result in premature battery failure. Known parasitic drains occur on all Q7s from bad door handle sensors, which weakens and kills all batteries prematurely, regardless of their capacity...easy to fix this and costs nothing. The more bad handles, the larger the parasitic drain. And of course, you can always have other issues on your car specifically, but these are the known issues that are very simple to resolve.
it makes sense, yes I have a 2 door handles sensors faulty and causing leakage which I didn’t fix and I reckon these made my new battery weak, I did code the battery and checked I will recheck if I did it right or not, I have 80 Ah on my battery which I think is not good anymore because the battery is weak already, can I ask you how Can I fix that terminal #15 for door sensor issue and where is it located?
you reckon more the Ah is better? What about a lithium batteries they have more Ah capacity
You will find in Ross-Tech Wiki or in recent threads on here the BEM code listing for myriad sizes/capacity/technology, to make it easy to program the car if you buy an aftermarket battery that's lacking a BEM code sticker.
going to snip the wires today let’s see how it goes and will get Back to you guyz
Here's an ongoing thread that has BEM info and BEM codes for different sized batteries, etc.
hopefully Job done
NOW I have to throw a new battery under seat with coding will ask for the help once ready
thanks
