Is it possible to turn off the seat belt unplugged warning chime with vcds?
While I was in there, I added needle sweep at start up and gear indicator (instead of just D, I now have D1, D2, etc)
Here are the instructions if anyone else is curious...
Seatbelt Chime disable
Module 17 (Instrument Cluster)
Default Coding: 2641263
New Coding: 2641203
NOTE: Your coding may be different than mine. I used the following coding guidelines to change the next to last digit from "6" to "0"
<a href="http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Instrument_Cluster">http://wiki.ross-tech.com/index.php/Audi_Q7_%284L%29_Instrument_Cluster</a>
????xxx: Options
+0001 = Quattro (Standard)
+0002 = w/o Driver Information System (DIS)
+0004 = Vehicle with Clutch (NO Automatic)
+0008 = Second Tire Size Pair
+0016 = Tire Pressure Monitoring
+0032 = Adaptive Air Suspension
+0064 = Advanced Frontlighting System (AFS)
+0128 = Adaptive Cruse Control (ACC)
+0512 = Vehicle w/o Electronic Parking Brake (Standard)
+2048 = Switch Option for Bord Computer Levels
xxxx?xx: Country
0 = Germany
1 = Rest of World (Left-Hand-Drive)
2 = USA
3 = Canada
4 = Great Britain
5 = Japan (Left-Hand-Drive)
6 = Arabian States
7 = Australia
8 = Rest of World (Right-Hand-Drive)
9 = Japan (Right-Hand-Drive)
xxxxx?x: Seatbelt Warning
0 = No Seatbelt Warning
1 = Seatbelt Warning (EU-NCAP)
2 = Seatbelt Warning (NAR Old)
3 = Seatbelt Warning (NAR New)
4 = Seatbelt Warning (EU-NCAP incl. Passenger)
5 = Seatbelt warning (NAR Old incl. Passenger)
6 = Seatbelt Warning (NAR New incl. Passenger)
