Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Q7 battery 2 questions
Old May 15, 2022 | 05:44 PM
calgary-Q7's Avatar
Default Q7 battery 2 questions
My 2013 Q7 has the stock 915 105 DL 110 Ah 850 CCA battery. I would like to go with a battery that has more CCA for cold winters etc.
I have pretty much given up trying to find a non VAG battery with a BEM code. Does anyone know if there is a VAG/varta battery H9 size with more capacity ?
Does anyone know if the stock battery is Flooded or AGM ??
Thanks in advance
Old May 18, 2022 | 09:12 AM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
On a TDI, it's the glow plugs that do most of the prep work required to start the engine, thus the 110 Ah capacity battery, which is the largest size that fits the battery well. The OE battery in 4L Q7s w/o start/stop function (like they got overseas) is the flooded cell / wet battery. The AGM type battery is used in conjunction with start/stop engine fuel saving systems, as it recovers faster and is able to take a higher amp charging rate,etc. The main thing is making sure you got rid of parasitic drains on battery and charging system is on point to maintain your battery.
For a super cold winter climate, you don't need to reinvent the wheel on this car; it's all been done prior. Use the appropriate winter-weight oil for reliable starts for your climate. Get a fresh OE battery if yours is toast. You could go aftermarket, but the OE battery is 4yr warranted, affordable, and perfect for this car. The OEM, rebranded versions are fine too, just be sure to get a 'fresh' battery with a recent born-on-date, and ensure it is charged fully AND TESTS GOOD prior to installing it under seat in the car.
Other than that, you do whatever you do in your colder climate, whether that's an external block heater, oil heater, enclosed garage, battery tender, etc. You live there and you know the drill. Oh, and if TDI engine, have winterizer additive for your fuel (to keep it from gelling; winter diesel is blended w/ kerosene to help keep it from gelling, but you made need to supplement) and don't forget to check the antifreeze protection level/coolant to provide appropriate coverage for your expected low temps.
Last edited by '10Q7TDI_Prestige'; May 18, 2022 at 09:40 AM. Reason: Winter Diesel / Car prep
ElliottG
A4 (B8 Platform) Discussion
Mar 3, 2022 07:54 PM
Gtopb
A4 (B9 Platform) Discussion
Nov 1, 2021 11:34 AM
Peter J.
13
Nov 16, 2019 07:15 AM
r1racer
12
Oct 25, 2011 04:45 PM
tauruspower
Telematics Discussion
Nov 23, 2010 02:31 AM
