Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Q7 Laundry List?
Old May 18, 2022 | 06:34 PM
HeathK's Avatar
Student of life.
Default Q7 Laundry List?
New Audi member and Audi owner. Owned a 2018 Q7 Prestige for about 5 months now and I have questions for someone with expertise and wisdom, you guys.
Please let me know what is “Audi”, what is not and what is because of 50k miles so I can figure out whether to keep the car, fix it and/or get rid of it. Your aid is much-appreciated, thanks ahead of time.
1. Steering correction when heading straight but passing a turn lane, for example.
2. The backup cam randomly reverts to “Graphic” about 50% of the time.
3. On the MMI, “North Up” randomly reverts to “Heading Up” about 75% of the time.
4. After Audi tech adjusted the auto door Latching mechanisms, the passenger front door inconsistently functions.
5. This same door has been found to be cracked opened, car locked, and raining.
6. Passenger door mirror does not return all the way up to previously set position after backing up.
7. Wipers “jump” sometimes from their off position I think when turning off the car.
8. Lane departure doesn’t always turn off when using turn signal hence vibrating the steering whee.
9. Resume CC behind a turning, but out of the way vehicle, it slams on brakes anyway
10. While passing another car from probably too close behind, vehicle seemed to try to prevent steering maneuver to pass.
11. Slow, steady braking with cruise control while driving straight and car in front or signage telling car to slow/stop.
12. Perhaps related, curve detection happens even though there is no curve
13. Steering correction suggested grabbing wheel while driving straight. I was at 10 & 2.
14. Vehicle driving straight, it pulls to right or left when driving over humps in road
15. Speed limit sign reader inconsistent and shut off within about 5-10 mins of each other.
16. Rear lid closes by foot while sitting in trunk having a picnic.
17. Altimeter randomly adds a couple hundred feet…at sea level.
18. Quattro rumble is normal? Come onnnnnn.
19. “Crunchy” noise while steering and parking/driving slow. Noted mostly on clean, concrete driveway but it kind of reminds me of rocks under the tires while steering while sitting still.
#GoodTimes
Old May 19, 2022 | 07:44 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
You are posting about the Gen 2 Q7. If you'll notice when clicking on 'forums', and selecting Q7, there are two separate forums listed. Gen 1/Mark 1 cars stopped production in 2015. Gen 2, or the Mark II (4M Chassis) Q7s began with model year 2017 and are still in production...it's not the same car at all; basically nothing in common with the Gen 1 Q7, which is a tank on wheels. You will need to copy/paste your post into a new thread in the Mark II Q7 Forum, as that is where you will find your answers.
There's a ton of issues with the Gen 2 cars and several recent model years are labeled by Consumer Reports as "Used Cars to Avoid", including the '17 and '21 Q7s.
Good luck with yours.
CFLQTRO
Q5/SQ5 MKII Discussion
21
Jun 7, 2024 08:27 AM
4DoorsMoreWhores
A4 (B9 Platform) Discussion
Feb 1, 2022 06:24 AM
Ash_174u
A7
Jan 2, 2021 03:29 PM
Motowey
Jan 31, 2020 01:58 AM
