Audi Q7 Airsuspension problem 01772
I have a problem with Audi Q7 2013 model.
Air suspension
When i start the car its no problem, suspension works fine, no codes. I can put it in all steps.
When start driving over 50 km/h TPMS light comes on and i get code 01772.
As long as the suspension works, if I change between comfort and dynamic when driving i get no code.
The code comes after it stays in correct level.
I have tried change the Block Valve for a new aftermarket but doesnt help.
The connector for Block Valve looks good.
Thanks if I can have som help with this.
Error code 01772 - Signal from Level Control Pressure Sensor (G291): Short-Circuit to Ground (GND)
From the Ross-Tech Wiki (Google search results):
Possible Causes
- Wiring issue between G291 sensor and J197 Control Module
- Faulty G291 sensor
- Faulty J197 Control Module
- Air leak in system
Possible Solutions
- Inspect and repair wiring harness
- Inspect for leaks with soapy water
Additional Notes
- When found in the VW Touareg, see Technical Bulletin V4305XX or the newer version of that: 43-05-02 | TPI 2010801
- When found in the following Audi vehicles check TSB 43-08-16 | TPI 2018765
- https://static.nhtsa.gov/odi/tsbs/20...23920-9999.pdf NHTSA
- 2006-2009 (4F) A6
- 2013-2013 (4G) S6
- 2013-2013 (4G) S7
- 2004-2010 (4E) A8
- 2011-2013 (4H) A8
- 2007-2012 (4L) Q7
- May be stored in conjunction with 00453, 01583, 01770, 01772, 02645 and/or 02646.
Don't forget the simple stuff like the squirt bottle with water and dish soap mixed in to find any leaks (test static and with compressor running), but you really want to scan the car with the compatible VAG-type scantool if you are not already using one like OBD-Eleven, Ross Tech VCDS, etc. Otherwise you aren't seeing the full array of trouble codes the car has stored inside it.
But the only code the comes upp is the 01772.
I have also tried with VCDS and its the same code.
The blockvalve is replaced.
The connector and wire to blockvalve looks fine.
The code come at the same time after start driving and come over 50.
I have try diffrerent metods when driving and if i let the compressor works all the time and change level it want come any code.
Here's the Ross-Tech Wiki data on the compressor code BTW...it is not likely relevant as your actions were the cause of the shut-down/protective action, although you should look to see if this code is recurring (has other historical instances), or if the counter on it shows it has not been presented prior.
01577 - Turn-Off due to Over-Temp: Upper Limit Exceeded
Possible Symptoms
- Air Ride Suspension bleeds down
Possible Causes
- Air leak in Air Ride Suspension System
Possible Solutions
- Locate and repair air leak
Special Notes
- On vehicles with Air Ride Suspension, a leak in the system will cause the Air Compressor Motor to run too long and flag this code.
If you bought a knock-off valve block, you may be creating your own headaches, or just didn't resolve the issue.
Here's from another write-up of this issue, and I'd follow this one, as you may have overlooked checking the height sensors on the car, and the required re-leveling calibration you have to do on air suspension cars when replacing the height sensors or valve block, etc.
Special note :
When found in Audi Q7 or Audi A6,Before changing level control module pressure sensor G291. Check for the reading or all height level sensor. If found any fluctuations in level sensor then repair or replace them first. That will solve the problem . If it does not solve the problem then go for checking leak pipe, failure of level control module, or damage wiring harness of level control pressure sensor g291.Last edited by '10Q7TDI_Prestige'; May 27, 2022 at 01:33 PM. Reason: Followup
