09 Audi A6 C6 3.0 No Start, No Crank. Starter Replaced. Fuses good.
I recently picked up an A6 with a no crank no start issue for a good deal. The previous owner had been driving it and the starter went out. Replaced the starter and it worked for about 2-3 days and then stopped working. Starter and fuses tested good. He says the Steering Lock Module needs to be replaced & tried buying one from a junkyard, but never installed it, just tried plugging it in with no luck. So, he gave up and sold it and here I am. I have tried to reset the codes and also do the bypass with the hazards and brakes lights etc. trick with no success. Also have replaced the battery with a new one as I bought it with a dead battery. Still no change. Everything turns on, just no crank no start.
I have the module rebuild kit and all the appropriate tools to desolder and resolder the one in the car, so no coding is needed. I understand its a fairly common problem with these Audis. I just wanted to post my auto-scan to get your opinions on the matter as I am also getting a P3052 "50 short to plus" amongst some other codes.
Attached is my vcds scan.
Any help is greatly appreciated, thanks in advance!
-Cole
