A6 C6 tailgate problems
The power tailgate has some weird problems that are getting annoying:
when opening, most of the time the boot does not fully open, sometimes opens about half way, sometimes none at all, very occasionally all the way.
The button used to close the boot often does not work, occasionally if the boot is up and I press the button it'll try to open it even more which is quite scary.
The 3rd brake light also had a fault a couple of weeks ago and wouldn't turn on, however that went away after a day and hasn't returned since.
Any ideas on how oo diagnose and fix the tailgate? Thanks in advance for your help!
The struts for the electric tailgate are specific to cars that have electric tailgate - I read somewhere (!) that these are475mm stroke and 600Nm units - Mine struggled with this type.....
Changed mine to 4F9827552B which have a 490 mm stroke and 650Nm and it works a lot better......The switch in the trunk lid is a very simple switch.....I would change it out - or if you are feeling brave take it apart and clean it!
If you have VCDS you can check if the switch is working
Mark
