A6 C8 (2023) - Error identified during coding after installing tpms sensor
I attached the TPMS sensor to the tire on the A6 C8 that I am operating and organized the sensor and wiring. Sensors are sold at Aftermarket.
I was not satisfied with the genuine TPMS sensor, which was confirmed by the number of rotation of the existing wheels, and we installed a device that could check the temperature and pressure of each wheel through coding
Since then, coding has been carried out, and the pressure and temperature of each tire can be checked by software program, but the sensor of each tire is not accurately located. The code shows Unknown.
Can you imform me why the TPMS sensor is correctly installed on each tire and the software checks the temperature and pressure of the tire but it doesn't show up on the vehicle display at all?
Thank you
