A6 C6 2006 Avant Bank1 0 Compression Bank2 155 Compression
It ran rough at first when I bought it. Thought maybe it was timing. Figure that's a repair for a shop not my level. So I started doing basic repair stuff. Then tried to start it last year. Eventually gave up didn't start. But it did run before I started working on it. Stored it over winter. Back at it now.
I'm at the point of trying get it running again and now can't get it to stay running. It stumble starts for 30 seconds then shuts off. I got it running today and kept it running only by gassing it and keeping rpms at 3K. Not lots of noise but some coming from engine area.
Last year I did a compression test on all cylinders with plugs in place. Bank 1 came in at 270psi ...all 3 cylinders. Bank 2 came in at 170 all 3 cylinders. So that was ODD. As I've tried everything with sensors etc... I decided to do compression again year later. Pulled Plugs on Bank 1 they look clean but gasoline covered. Bank 2 look to be covered in dry carbon... sign of rich mixture. So I do the test. 155psi all 3 cylinders on Bank 2 and 0 psi on Bank1 all 3 cylinders.
I have a broken chain some where don't I and the valves on the Bank 1 side are open or shot. Any help is appreciated. I'm still not sure how it could even run with no compression on Bank 1 side. OR I'm doing something wrong. Which is possible.
Thanks-JH
Would suggest to not turn engine over with the starter anymore in case timing has jumped gear teeth and valves are not bent yet. If the valves are not bent then at least you don’t have to repair the cylinder head and *simply* need a chain service.
Could use a bore scope in spark plug holes to see if piston were impacted by valves.
Could pull valve covers and rotate engine by hand and check cam shaft alignments. This would verify which cam(s) are out of time and by how much. Can jump one tooth maybe two teeth without bent valves but usually by the time three teeth jump then the valves are likely bent.
I'll report tomorrow and if I can get some pictures from the Amazon procured scope I will. We'll see if the resolution is there to provide any answers.
Thanks-JH
Some questions then to give me direction.
1. Valves have contacted pistons. Is this correct? So head or heads need to come off?
2. Can I trust that impact didn't hurt pistons, rods, and crank.
3. Lots of carbon in other head as well. Seems like its both heads off as a minimum? Is this correct.
4. Where would I go to get it done. Are there places that rebuild Audi engines , the 3.2L. Should I just replace this thing to ensure nothing else is wrong?
Thanks-JH
The carbon buildup inside the intake valve ports is a feature of the 3.2 and all DI engines of any brand. A decarb service is considered regular maintenance for DI engines.
Search your local area for a 3.2 engine service shop for a timing chain service and cylinder head repair. Option to find a good used cylinder head and swap it vs rebuilding the existing damaged Bank1 head. Another option is find a good used 3.2 and replace the engine, but of course perform same inspections to verify engine is good and perform a timing chain service prior to installation. No point installing a good used higher mileage 3.2 without a timing service otherwise same thing will happen again. Maybe you can find a pro shop seller of a good used 3.2 with proof of timing service already done and ready to install?
When rotated to TDC then each of the two banks cam end offset notches line up with each other in order to install a cam lock bar. By looking at the clocking of the notches at TDC then it will tell you which cams are out of time and by roughly how many degrees.
