Audi A6 timing issue
All tensioner and guides are new and both upper chains new.
I pulled codes and have a P0341 and P0366, cam pos. sensors codes.
I'm looking for a place to start on trying to figure this issue out.
Could try swapping locations of two cam position sensors.
Sometimes the cam adjusters get gummed up and need a cleaning. Ross tech says this note about P0366:
Special Notes
- When found in the 3.2 FSI
- Please see TPI 2012630 for information about Camshaft Adjusters binding.
- If the camshaft adjuster is suspected you may be able to swap the left and right side components to see if the fault code moves (providing the parts are compatible).
Special Notes
Can you post the two full vag codes data?
What happens if you take revs up to 2.5K - 3K and raise the oil pressure?
So it looks like I'm going to be dropping the motor again figuring out the oil leak and replacing that upper passenger side tensioner.
My question is what would cause that tensioner to go bad that fast?
What should I be looking for as I go back through this process?The tensioner brand is INA from FCP EURO PARTS, is that where I messed up?
Any help would be greatly appreciated.
Both times the passenger side tensioner I could press it in with my hand. Drivers side was stiff. Weird.
Ive just given up replacing the tension for a third time and just live with it.
