2010 S6 Driver seat not working
There is an aluminum canned green label 30A fuse tucked up high behind driver lower dash kick panel and just below the steering column for the driver seat control module mounted under the driver seat. In the absence of a vag scan then suggest inspect the fuse, the wire harnesses and control module under the seat, the control panel on the side of the seat. Note the lumbar gets separate power from the rest of the seat motors.
