Adding another audi to the sable
and two, you need bluetooth adapter, I can recomend Mr12Volt, works great when it works.
Wired works 95% of time. Sometime I have to plug in/out to get going. I also added front and side camera, works great.
-tishi
So 2007 is anyone's guess.
I cannot tell what could be wrong with your Avant. if it is maintained and not flooded or something, it can run to 250K as I observed myself.
I would flush the brake fluid, and power fluid, replace the fuel filter, and replace the cabin filter. remove snow screen.
Also, check the rear window washer hose. it is known to leak on the amplifier.
I saw edgemotors posted video on youtube explaining how to recode it. But you need a different API, not the vagcom.
