A6 4.2 V8 Rough idle and stalling here are my symptoms
My A6 4F2 with 4.2 V8 (BAT) and 220'000km (136701 Miles) has some annoying problems:
- Rough idle and at low RPM. The engine shakes pretty bad and car has less power. At higher RPM it runs fine. So it happens when the car starts or goes to stop ( Red lights, ...) Sometimes the call will run fine for a few days. But on a bad day it will happen a lot. If I unplug the MAF, it fixes the problem. I have already replaced the MAF, but it changes nothing. With MAF unpluged the car runs fine can't reproduce the problem.
My mechanic says it might be some bad fuel injectors, some water in the fuel, or a bad head gasket
but he said he did not find any oil or over-pressure in the coolant tank. He tried to swap spark plugs positions to see if it could be this, but apparently no.I will try to put some isopropyl alcohol in my tank to see if it goes any better.
VCDS Faults as 11 september 2023
On 12 june 2023 I got these:
Any ideas, how can I try to find the cause ?
Other things my car has, but I think it shouldn't be related:
- The engine has some mini oil leaks in the middle front. But I don't need to refill too often
- The AC/Ventilation sometimes blows very hot air but only on left driver side and a bit on right passenger side, but the center blows cold air. This only happens after driving for a while and after sudden deceleration. Any ideas what this could be ?
Candidly, use the fuel trim data to learn whether the sensors are asking for more fuel (+) or taking fuel away (-). Use this to inform a systematic check for air leaks or fuel system issues.
Just my 2 cents
Ignore the rich and lean codes for now as they are likely byproducts of the source problem.
The codes to resolve are:
16485 - Mass Air Flow Sensor (G70)
P0101 - 008 - Implausible Signal - Intermittent - MIL ON
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - Intermittent
Why add iso-alcohol to the fuel tank?
Need a vag scan of Address 08: Auto HVAC system as it will report which sensors and or dash flaps that are not working properly.
Last days the car ran fine. Today I logged some sensors using the vag-com (Air intake temp, Mass air flow, throttle position, Engine RPM). But as there were no noticeable hiccups today, I guess I will try to do it again when the car is acting strange.
Graph of trim values. You can see at the end the car wag rough idling.
So then I logged MAF values to check:
You can see how the engine RPM is unstable, lots of little waves on the line. And MAF values are a mess. In the middle, I put some throttle, we can see it fixes MAF values.
Then I stopped the car and started it back on and the rough idling was gone:
Here we see RPM is more stable and also MAF values. I put a bit of throttle in the middle.
So this is very strange because I replaced the MAF because the old one was behaving the same and no changes. Maybe I have to say that in the past I already changed the MAF like 2 times I think. Maybe with 1-2 year interval each. Symptoms were the same, but after changing it, it fixed the problems. But not this time...
I checked the connection the the MAF but it doesn't look very bad to me ??
Maybe my VCDS is very old ?
Then I checked the new faults code (I removed again the cable to the MAF before checking the codes):
None of the data shows the air intake sensor acting up which suggests it was working during the point-in-time data logging events. Would be interesting to see what it reports when it is not reporting correctly to trigger the DTC.
The LTFT could be going overly negative because of the bad MAF readings and suggests running rich. This is why your mechanic suggested possible “injectors” especially if they are leaking extra fuel. Normal readings are ideally between +5 -5. Could try a high quality DI fuel injector cleaner additive to the fresh tank of Tier 1 highest available octane fuel but caution do not exceed the instructions concentration.
Interesting to note the MAF readings are all over the map only at idle and appears to be working above idle. You may need to inspect the MAF wires all the way back to the ECU for cracks. Could try reseating the ECU connector with battery disconnected. With wiring diagrams could perform continuity measurement from ECU connector to MAF connector 5 wires. Measured with a volt meter, what is the battery voltage at idle when MAF is acting up?
Although your MAF connector pic is pretty good, it is a little hard to see the pins. Look close for damaged or spread pins in each of the 5 terminals. Could do same visual pin inspection at the ECU connector for MAF wires. The red circled one in this pic shows the clearest view of how the two sides are spring loaded and should be in contact with each other when not connected.
If engine is indeed running rich then a functional BxS1 will tell ECU to pull fuel. If available then testing MAF in another working 4.2 is a good idea as well. Watching heat bloom in the fuel rail after hot engine shutdown is a good test for stuck open injector too. DI engines should not have raw fuel in cylinders after hot shutdown. An undetected stuck open injector will eventually destroy the engine.
It is possible there is more than 1 issue such as stuck injector(s) and a problematic MAF connection and possibly intake air temp sensor.
